07-04-2021, 03:35 PM | #1 |
Rep 837
Ohlinds R&T Coilover Adjustment
Will be taking the car to Laguna Seca end of July. I've never adjusted these myself but want to do so at the track. From what I can tell the damper adjustment is at the bottom of the strut on the fronts and the top of the CO for the rears. Do you access the top of the rears from inside the trunk? The only video I could find on another car you have to remove the trunk liner to get to it. And for the fronts so you simply jack up the front and adjust them from below? Currently i'm on the softest setting but may want to try some stiffer settings when at track. Also if any of you have been to Laguna if you have any settings suggestions or just general advice I'd love to hear it. I've only been to Fontana ROVAL and Chuckwalla so far with this suspension. Thanks
Current Ride 2020 M4 Competition/ Alpine White / DCT/ Full Black Leather / 19in Gunmetal / Executive /LED/Ohlinds RT/SSR DP-CP-Intake/AP Essex 9668/Bootmod STG 2/ VRSF DP
07-04-2021, 07:59 PM | #2 | |
Rep 98
07-08-2021, 06:32 AM | #3 |
Rep 648
You don't have to jack the car up to adjust anything. Just lay on something and turn the wheels max, then you reach the adjusters. Rear is no problem to reach either.
07-09-2021, 04:12 PM | #4 |
Rep 376
Check on this forum a post related to deep dive on Ohlins. great material as reference. I typically go F - 10 clicks from full / R - 15 clicks from full.
more than that doesnt make sense based on the curves but also feedback from the car at the track. |
FaRKle!4042.00 Intensemojo87.50 |
07-19-2021, 05:03 PM | #6 |
Rep 6,764
10 clicks is middle of the scale.
17 clicks from full puts you just 3 clicks from softest setting. Or am I misunderstanding it, and you guys are running 3-5 clicks from hardest setting?
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
