07-06-2021, 03:58 PM | #1 |
Rep 123
Drives: 2021 BMW M2 Competition
Garage List 2018 BMW X5 35d [0.00]
1970 BMW 2002 [0.00] 1991 BMW M5 [0.00] 2005 BMW 330 ZHP [0.00] 2021 BMW M2 Competi ... [0.00] |
F15 Diesel Guidance
Just bought an AW 2018 F15 Diesel with 21k miles from Braman BMW in Miami. I am flying this weekend to pick it up and drive back with my wife. 30 year BMW owner, first diesel. So, since I will be driving almost 1500 miles of highway, and not knowing what the previous owner used for fuel, I'm looking for advice. First, this X5 just passed the CPO certification and I requested a printout of the sheet from the Service Department. I see nothing about any engine or trans service at this time and it states almost 8k before the next service. I usually only go 4-5k on my oil.
My question is this, not knowing what fuel the guy who was leasing used, is there a recommended fuel system cleaner/treatment I should use during the long trip to potentially clean up the system, or am I being too anal about this? I know to look for good fuel at only name brand stations, not places like 7-11 or anyplace that is filling up the underground tanks as it stirs up all the sediment. I will address the oil and other fluid items when I get home. Luckily is it still under factory warranty for a year and the CPO warranty for an additional year after that. I wish I had a photo to share, but since I sent them the funds, they took down advertisement off the BMW CPO sales site. I will take some when i get it home. It is Alpine White with the Terra Brown Dakota interior and Poplar Grain wood trim, Heated Comfort seats and wheel, Y-Spoke 451 wheels and LED Adaptive. I have a 2005 Highland Green Metallic 4.4i Sport that this will replace, so familiar with the platform. Thanks for any advice. |
07-06-2021, 07:54 PM | #2 |
Rep 347
Ride out your factory warranty. Once it is done slap on a fuel filter kit to save that cp4 and or upgrade to the revised one . As for fuel treatment. Run some hotshots diesel extreme every so often and use hotshots EDT LX4 , can use it every tank just to keep ur fuel system lubricated well. You have low mileage so just keep ur fuel change/ fuel filter at a good amount not the bmw recommended intervals.
07-07-2021, 08:47 AM | #3 |
Rep 21
Drives: f15 X535d, f13 650, e39 m5
This. I ran a bottle per year through mine when I had it (1/2every 6 months) and it still pulled like a freight train to the day I turned it in. Still miss the torque of the diesel. Thanks a lot VAG group for ruining diesel for everyone. Hot Shot's Secret P040416Z Diesel... https://www.amazon.com/dp/B00IUGFZE2...p_mob_ap_share |
07-07-2021, 05:57 PM | #4 |
Rep 123
Thank you Atwal187 and nje39m5 for the advice. I will probably stop and pick up some Hot Shots for the 1500 mile return trip. Seems like the perfect conditions for either cleaning it up, or maintaining whats already been done. I can't imagine there is terrible buildup in only 22k miles, but I don't know. A $20 bottle of cleaner sounds like cheap comfort and a good regimen to start.
Guessing I have a lot to learn in the coming years. I appreciate it. |
07-07-2021, 10:57 PM | #6 |
Rep 123
07-08-2021, 01:40 AM | #7 |
Rep 364
Drives: F15 M50d / ex E90 335i / Panda
Another kind-of-piece-of-mind advice:
Once a month have a stable and above the 60mph drive that lasts longer, than 30-40 minutes - that will let your DPF regenerate by burning soot and ash from inside. Best scenario - get Carly or something similar, where you can force the car into "regenerative drive" mode. And - as you said - stick to the best fuel you can find around. This, given the US fuel quality, is critical. |
F87 S55158.00 |
07-08-2021, 04:22 AM | #8 |
Rep 1,270
Regeneration process burns soot but not ash. Ash is collected into DPF and will eventually clogg it. That's the time for a new one.
Regeneration is done at any speed or load of the engine, if there are no DME errors and you have sufficient fuel remaining in the tank. |
07-08-2021, 04:48 AM | #9 |
Rep 364
That's very interesting, thank you!
Does chemical cleaning of the DPF (either by injecting anti carbon liquids by sensor hole before DPF or by commercial companies "wash" process) help remove the ash and does indeed unclog it? My car is at 150k miles (little over 250kkm) and while Carly indicates marginal amount of soot and ash (single grams) I suspect it might have something to do with cold start rpm floating/wobble. 2014 M50d Diesel Runs only on Shell Vpower diesel |
07-08-2021, 10:25 AM | #11 | |
Rep 1,270
F87 S55158.00 |
07-08-2021, 01:54 PM | #12 |
Rep 364
As far as I remember, the price for DPF (just the part, no labour) was around 2k EUR, total was around 2.8-3k EUR. Cleaning is around 350 EUR, worth the shot in my opinion.
07-08-2021, 06:11 PM | #14 |
Rep 1
X5 Diesel
Yes- I have a 2015 X5D- love the car, tremendous acceleration, superb handling awesome vehicle. At 70K the repairs started $5,000 for a new diesel tank replacement and other repairs. Today $4,000 for a diesel filter, sensor, and complete fuel injector replacements (all 6). That's $9K in two months.
07-09-2021, 06:30 AM | #15 |
Rep 239
F87 S55 , i'd consider this additional fuel filter and water separator.
https://www.tunemyeuro.com/tme-fuel-...separator-kit/ |
F87 S55158.00 |
07-10-2021, 04:47 AM | #18 | |
Rep 5,267
07-11-2021, 05:01 AM | #19 |
Rep 347
I've been driving 3.0l BMW diesels for 20 years and NEVER had a dpf clog. Its quite simple, no diesel with a dpf likes lots of short little journeys all the time. They thrive on being worked quite hard and periodic long journeys. The dpf regenerates automatically when certain criteria are met. It needs to be at running temperature and travelling consisently for a period of time and crucially must have a certain fuel level at the time. I can't remember the exact amount but probably over half a tank as the regen uses more fuel when operating and sometimes you see motor run a little warmer for a short period or hear the process completing when you park / switch off. This is all normal. I have tried fuel additives etc and them defintely help the engine sound a little less clackity but didn't seem to impact regens at all. Put simply these engines love a good workout and if you are worried about tickets etc simply drive a few miles on a journey in manual mode and keep the revs up a little. Garages will advise dpf cleaning etc to make extra $ all the time....... just give a periodic thrashing.... job done!
G20 M340d X-Drive M Performance, Black Sapphire, HUD, Adaptive Susp...... previously
F31 335d Xdrive Shadow Edition M Performance, Individual Tanzanite Blue, HUD, Adaptive Susp, Evolve-R Map, Xhp Stage 3 E60 535d Msport Carbon Black/E39 530d MSport, Black Sapphire/E34 525i MSport, Avus Blue/E34 520i MSport, Briliant Red |
midlifecrisis810.50 F87 S55158.00 |
07-14-2021, 03:08 PM | #20 | |
Rep 123
Great Advice...
08-04-2021, 10:41 AM | #21 | |
Premium Monkey
50
Rep 80
Also, thoughts on 1 micron vs 3 micron filter? |
F87 S55158.00 |
08-04-2021, 04:37 PM | #22 | ||
Rep 347
And when the updated fitment one for DHP will be available |
