BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
European Auto Source (EAS)
      07-12-2021, 09:26 PM   #1
romero1990
Drives: E92 M3, F25 X3
2017 X3  [0.00]
2009 M3  [0.00]
test new injectors?
HI all, I bought a new set of injectors to replace the ones in the car (130k miles). How do I test if the new injectors are working before putting them on? AFAIK, a stuck injector will cause hydrolock and break the engine. I feel it is necessary to test before putting them in for good.
      07-12-2021, 09:45 PM   #2
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
Most people don’t test them first. I just swapped the new ones in. But if you insist, put them in a rail that fits this type of injector since you probably do not have any other type of injector holder (you may not have any rails, either) and apply 12V and touch the other wire to ground. Of course this won’t tell you much other than that the injector sprays. What a worrier or someone very thorough would do is send the new injectors out to an injector tester to test flow and spray pattern. I have done this before.
      07-13-2021, 06:00 AM   #3
DukeofAlexandria
DukeofAlexandria's Avatar
633
Drives: 2007 E85 Z4 / 2013 E93 M3
2013 BMW M3 E93  [0.00]
2007 BMW Z4 E85  [6.00]
If they are new like you state, why are you worried? I've replaced a multitude of injectors in my time and never found any to be defective. Furthermore, you'll usually be able to hear a non firing cylinder long before you do any damage.
But like pbonsalb said, if you're that worried, apply 12V to each injector to see if they start clicking/opening. I personally wouldn't find a rail to put them in, but would just bench test. Either method will work though, good luck.
-Duke
      07-13-2021, 10:12 AM   #4
pbonsalb
It is a pain to set up with fuel at the correct pressure and an injector holder. On simpler cars you can just pul the rail and injectors out of the manifold and spray into a long thin container. Not easy on the S65. Plus if you are this worried you want to know the flow and pattern is correct and that is most easily done by sending them out for testing. Might be $25 each injector. Marren, Five-O, RC Engineering and many other shops offer this service.
      07-13-2021, 11:17 AM   #5
SAMM3Y
SAMM3Y's Avatar
3087
Drives: 2008 m3
You can send them away for testing if you don't need to install immediately. Also check for a local service. I live in Sacramento and there's a guy named Dr. Injector who tests for $10 per/injector. Cleaning and replacing orings cost an extra $15/per. But if they're new oem I would simply install.
9ers
      07-13-2021, 12:01 PM   #6
kolosy
Drives: over potholes
you got your eeuroparts ones delivered too, didn't you
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3
I think I have an M3 problem.
      07-13-2021, 12:13 PM   #7
romero1990
2017 X3  [0.00]
2009 M3  [0.00]
lol yeah. one of the box was a little smashed. I'm like "hmmmm" and then going into "should I test them or just use"
      07-13-2021, 02:21 PM   #8
tsk94
tsk94's Avatar
Drives: E92 M3, E82 128i, F82 M4, E36
Take them to a shop and have them tested and cleaned if necessary. Simple.
      07-13-2021, 02:56 PM   #9
Vedubin01
Drives: 2013 E92 M3
The ones for $20 each?
      07-13-2021, 02:59 PM   #10
Senpai
Senpai's Avatar
Hong Kong
483
Drives: E90 M3
I've been wondering about the eeuro ones as well. Are they they genuine bosch?
Jerez Black E90 M3 6MT
KW-AP Racing-Volk-Varis-Akrapovic-Recaro
      07-13-2021, 05:04 PM   #11
kolosy
yup
they've got the verification stickers on them, and look official. i'll try one of the codes and see, but don't have a reason to suspect otherwise.
Senpai482.50
      07-13-2021, 08:03 PM   #12
romero1990
2017 X3  [0.00]
2009 M3  [0.00]
they looks legit to me so far
      07-14-2021, 06:49 AM   #13
Senpai
Senpai's Avatar
Hong Kong
483
Drives: E90 M3
Just placed my order for a set to keep around as spares. Can't beat this price.
      09-30-2021, 10:33 PM   #14
Vedubin01
Drives: 2013 E92 M3
Any feedback on these ?
      09-30-2021, 11:40 PM   #15
romero1990
2017 X3  [0.00]
2009 M3  [0.00]
mine are in for 1+ month and seems running very good so far
      09-30-2021, 11:49 PM   #16
Senpai
Senpai's Avatar
Hong Kong
483
Drives: E90 M3
I'll be installing my set soon and they did verify they're legitimate bosch injectors.
m3post
