Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      07-13-2021, 12:17 AM   #1
DeathBear
Drives: 18 M3
Help Needed: AST 5100 Coilover Install
Hi All,
Here is my setup:
AST 5100 Dampers with Springs Upgraded 61mm ID Springs
Front: Spring Length: 180mm, Helper Spring Length: 100mm
Rear: Spring Length: 200mm, Helper Spring Length: 100mm
Front Dampers: The question I have is about adjusting ride height and preload. If the ride height is adjusted (lower) when the car is on the lift or full droop, the spring is loose and has play, no preload, and will need to be guided into the spring perch before it is loaded and on the ground. Is this normal/ok? If yes how would you preload the spring?
Any help would be appreciated!
Thanks!
      07-13-2021, 09:29 AM   #2
APR-M4!
Drives: 16 BMW M4
If the ride height and pre-load are adjusted together, you may need a low/no rate helper spring to keep the spring from flopping around. The helper spring should keep the spring in contact with perch at full droop.
      07-13-2021, 10:10 AM   #3
DeathBear
Drives: 18 M3
Thanks! So if I understand correctly, a longer helper spring is what is needed correct?
My other question is would it be fine for the spring to be loose under full droop or when the car is lifted if I leave the setup as is? I don't anticipate the car to be lifted during normal driving.
Thanks!
      07-13-2021, 03:16 PM   #4
Ant_tc
Drives: 2017 BMW M3 30 Jahre
Thanks!
Should not be an issue. My setup on another vehicle was the same(no helper springs) and the only thing you need to make sure of is when you lower your vehicle your spring seats straight on the collar.
      07-13-2021, 04:20 PM   #5
DeathBear
Drives: 18 M3
Appreciate the super quick response all!!
f80post
