07-13-2021, 09:30 AM | #1 |
Rep 104
Timing Chain Guides
Hi,
On my e39 540i Sport I changed the timing chain guides which was a time intensive job i would rather not repeat. I was wondering if the X5m has the same parts and issues? Are there any long term high mileage maintenance guides for these cars i should be aware of or where to look at some from BMW? Thanks, Frank |
07-13-2021, 11:49 AM | #2 |
Rep 304
Not remotely the same engine. While there are timing chains and guides, those are not a common issue on s63tu2
OnlyGerman363.50 |
07-13-2021, 11:57 AM | #3 |
Rep 104
07-13-2021, 07:13 PM | #4 |
Rep 1,564
Ya the S63TU should be good to 200k+ on the guides. On my N63, which uses nearly identical guides to the S63TU, I pulled the heads at 138K to clean up all the carbon from the leaky valve stems and the guides looked great, now at 170K and still going.
Good thing too, as Procedure for changing them is the same for the n63/s63 and all TU variants...Roughly 40 hour job as engine must come out and near complete disassembly. |
07-14-2021, 01:46 AM | #5 |
Rep 901
The timing chain guides were a real issue in the M62 engines (V8 E39, X5-E53). My X5-E53 (2005) has the N62 engine and that does not have chain guide issues. Valve stem seals are an issue on the N62 but I changed mine without removing the heads using a tool that looks like the AGA tool but at a fraction of its cost.
07-14-2021, 08:12 AM | #6 | |
Rep 104
07-14-2021, 12:25 PM | #7 | |
Rep 1,564
I had 15 hours alone in removing and installing the lower intakes and making custom tools to access the bolts while it was in car. Not only do you have to remove the nuts that hold on the intakes, but you have to remove the studs from the cylinder head so the head can slide past the lower intake when removing them as there is not enough room otherwise. The frame is essentially the same on the F85 as the E70 do if you look down where the lower intakes are, you can see how close it gets to the frame rail and steering rack. Putting it back together is even more fun, not recommended to do without a lift unless your crazy or a masochist, or little bit of both like I appear to be . Removing and installing the lower intakes when the engine is out of the car takes about 20min btw. |
07-14-2021, 12:39 PM | #8 | |
Rep 104
