07-17-2021, 06:32 AM | #1 |
Rep 365
Water when I open front doors -is this normal?
When I open my front doors up to a few days after a rain storm a bunch of water drops to the ground under the doors. If I had to guess how much water it is I would say its probably half cup on each side. I don't remember this happening when the car was newer. It is a 2018 35d. Is this normal?
07-17-2021, 10:22 AM | #2 |
Rep 334
Sunroof drains clogged. Search, lots of reported problem and fixes.
Use some string trimmer to shove down to clear the debris that's causing the blockage or hot water/cleaner. If under warranty and still badly twisted, take it to the dealer. They will take the front Q panel of and A pillar trim and straighten it out or run a new line. Some people also run a smaller OD tubing down to keep the accordian like OEM tubing from clogging by giving it a breather. Good luck. |
07-18-2021, 12:02 PM | #3 | |
Rep 365
07-18-2021, 01:38 PM | #4 |
Rep 1,222
07-18-2021, 07:12 PM | #5 |
Rep 34
If its coming from the door itself then it could just be the door drains being clogged with debris. The sunroof problem usually causes a wet headliner or floor boards. Doors don't exactly seal from water sliding down the window that's basically a wiper blade you see at the base of the windows on most cars.
07-19-2021, 05:31 AM | #6 | |
Rep 365
07-22-2021, 10:34 AM | #8 |
Rep 630
