07-20-2021, 12:08 PM | #1 |
Rep 233
*Deposit down - pending sale* I've owned this amazing car since 5/2017 and put less than a thousand miles on it! Solid car with no accidents. There's an entire file of maintenance records on the car that includes, Vanos bolts and hub, Valve adjustment, rod bearing replacement, Oil analysis, and more! All quality part upgrades Some of which includes: PFC brake kit front and rear Brake ducts APR aero - lip and wing KW clubsports with camber plates Sway bars Rear lower control arms Rear shock mount bushings Short Shifter Fab Speed headers Stromberg exhaust Engine and trans mounts Stack gauges Half cage (roll bar) Carbon fiber dash trim K&N air filter And more. The car is in Laramie Wyoming and has spent most of it's time with me in storage. As aggressive as it sits all the major chassis bushings are still rubber as the build was pulled back just short of a track car. All the boxes have Royal Purple. |
07-20-2021, 01:40 PM | #3 |
Rep 233
Thanks 👍🏻
The car includes the OE wheels with Bridgestone tires, stereo (removed to install gauges), bolt-in half cage that I pulled for more leg room, secondary air pump, alacantra steering wheel out of a E90 M (fits this car). |
