08-02-2021, 11:39 PM | #1 |
Rep 41
Drives: f30 and f15
NBT Evo Retrofit Issues
Hello!
I have a 2015 F15 with, from the factory, the NBT unit. My father and I decided to retrofit the NBT Evo headunit since, to us, this was the best way to get Apple Carplay. Plus, the Evo has a better interface, etc. It is important to note that ONLY the headunit was purchased (we already have the correct idrive controller and the Evo can be coded to work for an apix 1 screen). After installing it, wiring the OABR port, coding the Evo to the VIN, and installing the fsc's for the unit, everything worked! However, I wouldn't be posting this forum unless there was some sort of issue right. Shortly after install, we started experiencing the black screen issue that some of you may be familiar with. At first, this issue would only happen occasionally on start up, and a simple reset fixed it without a hitch. In an attempt to rid this glitch, I flashed the Evo to the latest software available with the latest PSDZ data from Shawn. This, however, was unsuccessful and actually worsened the black screen issue, meaning it would occur more frequently than before the flash. After searching forums for people that have had the same issue with this retrofit, some suggested to flash back to 03/2018 software, or get an Apix 2 screen. In an attempt to save some money (the apix 2 screen is not cheap), I tried the first option. I got the 03/2018 PSDZ data and attempted to flash the headunit back. Everything that I tried did not work; I tried every trick in the book regarding flashing to get this to work, and regardless of what I do, I end up with the headunit being stuck in flash mode. The only way to recover is to sw deploy with the latest PSDZ data to get the headunit back to normal. This is a section of the log file that I have: </blFlashTA> </previousRun> </talLine> <talLine cause="ta_1" startTime="20210729-213426.808" endTime="20210729-213426.816" diagAddress="63" baseVariant="HU_NBT2" status="NotExecutable" id="tl_28"> <preparation id="prep_2" cause="ta_1" status="NotExecutable"/> <authentication id="auth_2" cause="ta_1" status="NotExecutable"/> <finalization id="final_2" cause="ta_1" status="NotExecutable"/> Is there anyone that can make sense of this error? I should mention that the I-Step level for the Evo is 03/2019, and I have read somewhere you cannot flash back an ecu past its production date. If flashing back to an earlier software is not possible, should I just buy the apix 2 screen? |
08-03-2021, 10:20 AM | #2 |
Rep 2,529
Are you sure you don't have a defective NBT unit? Check this thread here, I don't think you need a screen to make it work properly.
https://f15.bimmerpost.com/forums/sh....php?t=1593428 |
08-03-2021, 08:02 PM | #3 | |
Rep 41
Drives: f30 and f15
08-05-2021, 07:31 PM | #4 |
Rep 41
Drives: f30 and f15
bump
08-06-2021, 08:24 AM | #5 | |
Rep 3,070
You can't simply downgrade it with just loading old software with E-Sys. Correct steps: 1. Virgnize (Clear V850) 2. Flash with 18-03 to be able to use APIX1 screen 3. Code it properly then load FSC set with CarPlay Fullscreen
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
08-06-2021, 04:25 PM | #6 | |
Rep 41
Drives: f30 and f15
08-07-2021, 08:11 AM | #7 | |
Rep 3,070
Either SSH manually or other solution. Prg file is DEV_UDS
08-07-2021, 10:12 AM | #8 |
Rep 41
Drives: f30 and f15
I am conveniently missing DEV_UDS. Is there any way you can share this file with me? Also, the Evo's Ilevel is 03/2019 I believe, but I updated it to 2021 Ilevel. Is this okay?
08-07-2021, 11:22 AM | #9 |
Rep 3,070
If you updated it to 2021 dev_uds is no useful for you
08-08-2021, 09:44 AM | #10 |
Rep 41
Drives: f30 and f15
08-23-2021, 12:14 PM | #11 |
Rep 41,224
Drives: 2018 Alpina B6 650ix GC
Yes, possible. I replied to your same PM.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
