08-06-2021, 02:11 PM | #1 |
Rep 1,264
RR AIRBAG - Dealer wants whole Strut
Came in for oil change and informed them the rear sags. Tech found RR airbag leaking from spray test. Have warranty so not worried. It was approved but warranty said dealer ordered a whole strut, not the air bag, as the SA and Tech said needed in report.
Common issue and everyone just changes the airbag, not sure why strut is needed. So simple case of dealer greed? Part is on order from Germany. |
08-06-2021, 04:03 PM | #2 |
Rep 5,025
Do you have to pay for it? If not let them do it.
Also, are you over 80,000 kms? If so, technically the dealer should replace both rear struts. It is odd that they want to replace it as the air bag and the schock are not a matched pair or anything… |
OnlyGerman363.50 |
08-06-2021, 04:09 PM | #3 |
Rep 1,264
I am not paying. 32k miles. Yes very odd. I will be asking for all old parts. I do not trust them. Probably got paid for strut but only replacing air bag.
08-07-2021, 06:46 PM | #4 |
Rep 123
Drives: 2021 BMW M2 Competition
Garage List 2018 BMW X5 35d [0.00]
1970 BMW 2002 [0.00] 1991 BMW M5 [0.00] 2005 BMW 330 ZHP [0.00] 2021 BMW M2 Competi ... [0.00] |
I agree, struts should only be replaced in pairs as a worn shock paired with a new one can induce different rebound rates which affects stability and safety. I would certainly insist that if they are going to replace one, they BOTH should be done. It would not be hard to find data supporting this.
Best of luck. Last edited by F87 S55; 08-08-2021 at 02:21 PM.. Reason: spelling error |
08-07-2021, 10:53 PM | #5 | |
<3 Flat Four
217
Rep 754
2011 335is Le Mans Blue
2016 X5 xdrive 35i Alpine White |
08-09-2021, 12:49 AM | #6 | |
Rep 5,025
08-11-2021, 07:50 AM | #7 |
Rep 1,264
Good points. That may be the official BMW procedure, but extended warranty (aftermarket) would only cover what has failed, so even if it was the RR strut, only that strut would be approved for replaced...as far as I know, they usually aren't that nice to go ahead to cover the opposite side.
Still do not have an definite answer from the $tealer on why they are replacing my entire strut instead of only the airbag. They are still waiting for the part. |
08-18-2021, 04:55 PM | #8 |
Rep 1,264
Spoke with dealer. Now they are saying my X5 does not have any sort of air suspension LOL.
I 100% have EDC with rear air suspension…. To them, my RR electric damper strut is "my issue" and causing the sag. What a joke. I'll be reporting this dealer and notified the warranty not to pay this dealer a penny. I will relocate to a Indy shop and have order the correct part. |
09-01-2021, 04:40 PM | #9 |
Ground Clearance?
237
Rep 1,656
What happened with this? I assume the dealer knows what they were talking about. They don't want you coming back with the car sagging again. No X5 has struts in the rear only shocks and an air bag. So the terminology is getting quite confusing in your posts.
09-01-2021, 05:45 PM | #10 | |
Rep 1,264
If dealer proceeded with repair, it would have been INCORRECT. The strut was not at fault, it was the airbag. |
