08-22-2021, 05:41 PM | #1 |
Rep 427
Eventuri plenum install, issues with engine misfiring as well as whistle sound
Guys, finally got around to getting one of the eventuri carbon plenums. I have installed it and reinstalled it but somehow it seems to going into limp mode and give a misfire condition on cylinder 1. Previously no issues on a 42K miles motor with plugs and bearings done about 7k miles ago. I think there must be a vacuum leak issue with the plenum but I have checked all connections to make sure they are snug and they are including tightening all the connections. There seems to be a noticeable whistle sound on idle. Car seems to idle perfectly, once you start driving it hesitates a little then it goes into limp mode after a few pulls.
I really want this to work but suspect the fitment is not perfect somewhere. anyone else have similar issues? Only mods are benvo tune which has worked flawlessly before and a dinan intake and bmw m exhaust. About to reinstall the oem plenum to see if it solves these issues... also wish there were some better detailed install instructions. Like, buy a temp sensor vs trying to remove the oem one.... tilt front to get front connector in, then get back connector in before tightenign down the center. Any help would be great, also found out mycarly no longer works on my s5 so need to get a new connector to use with my iphone....
2011 M3 Sedan
2001 M Coupe 2020 Macan Turbo 2018 GT3 |
08-22-2021, 06:28 PM | #2 |
Rep 427
Well I put back on the oem plenum, all the misfire codes went away including the whistle sound. So looks like either the plenum has a leak or is not sitting in like oem causing that sound. Will try again but I noticed that the oem plenum sits down more flush with the throttle bodies. Like some have said, they wish the lower piece was oem and the upper carbon, now I know why.
2011 M3 Sedan
DrFerry6734.50 |
08-22-2021, 08:37 PM | #5 |
Rep 526
I have the Karbonius plenum so take this for what's it's worth…
I did have to loosen the worm clamps more than I thought I should and put a little lubricant on the inside of the throttle body couplers to get the plenum to seat all the way down. From what I recall, the Eventuri plenum is a pretty direct copy of the OEM unit so it should sit just as low. |
08-22-2021, 11:54 PM | #7 | |
Rep 427
I took out a level to see if the tubes are level and they are perfectly level. I took the oem plenum and it slips on much easier and into place but I did notice even the oem one has a small gap between the tubes and the boots but very small compared to the eventuri. Welcome to any ideas how to get this to work.
2011 M3 Sedan
08-23-2021, 02:05 AM | #9 |
Rep 93
When installing mine I had to loosen the clamps much more than I needed for the oem plenum. I would push down one side and the other side would pop off the throttle bodies. I ended up having someone hold the plenum down so I could focus on tightening the clamps. Just took a look at mine and took a photo so you can compare to yours to see if there's any discrepancy after installation. It could be you got one that just doesn't fit the way it should.
08-23-2021, 02:19 AM | #10 | |
Rep 427
That is the one thing hate modding a car, you don't get the same tolerances like an OEM part. I think the plenum is just not designed for the variations in all motors like the oem one is. I will give it another go tomorrow to see if I can install it with no leaks,
2011 M3 Sedan
08-23-2021, 08:39 AM | #11 | |
Rep 427
One odd thing on mine. I can’t get the driver side firewall to seat down no matter how hard I push even with none of the hoses connected. Did yours go in?
2011 M3 Sedan
08-24-2021, 01:35 AM | #12 |
Rep 427
Well here is the update, I took Jamabdi advice. Over opened all of the clamps to almost falling off. This did allow the manifold sit a bit lower but still not like OEM. Then when I tightened one side the other would lift up. Ended up finding a solution using corks to hold down the corners while I tightened. This helped alot. Still the fitment is definitely not OEM. The stock one just slips in and you can feel positive engagement. The eventuri goes in but not the same.
Seems like tightening order matters as well, started at the back then, front then middle. Even after all of this work there still seems to be a very minor whistle sound. I test drove the car, seems like the ecu still needs to relearn as i reset and cleared the codes. It now drives without CEL but still has some minor stubling when accelerating but wow the noise it makes above 5K at full throttle. Even downshift blips are louder. I will see how if the driveability gets better. At least for those in future looking at this mod, it is not as simple unless the tolerances fit your motor perfectly. Some tips - Just buy a new IAT sensor, not worth it to pry stock one out without damaging it. If you do want to do it, remove rectangular piece holding it down then with a screwdriver gently pry it out. - to remove plenum, loosen all clamps, IAT sensor, rear hose, then the PCV valve hose. Installing is same order, put pcv hose on first, there is not enough slack to put on after manifold is installed. - Make your life easy, remove all the front cowl and cabin air filter, strut bars and intake box, makes access much easier. Would I do it again, I guess I will see if the ecu relearns the new air flow but hard to say until I have driven it some more. Thanks for everyone's help here. Here are some pics. Wine corks on both sides under strut bar mounts All reinstalled back.
2011 M3 Sedan
08-24-2021, 07:27 AM | #13 |
mTekMods
2169
Rep 2,922
youre doing something wrong, you can run this car with a open plenum and it wouldnt matter.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
08-24-2021, 08:01 AM | #14 | |
Rep 427
When I swap it to the oem plenum I have zero issues, and the whistling sound makes me suspect a vacuum leak. The fit is still not great so. The plenum should not be able to rock back and forth, yet it does, I took a flashlight to make sure the middle ones are not folded in and it does not seem so. Also the tightening feels fine and it gets tight too….
2011 M3 Sedan
08-25-2021, 12:35 AM | #15 |
Rep 427
Well after another reinstall I did get the plenum as low as possible and it seem to feel much better but still got the whistling sound even after getting everything tight. I localized the sound to the front of the box.
Driver side looks decent Same on passenger side I measured the openings, they are actually .4mm smaller than the stock plenum, consistently on all holes. 68.5M for eventuri, 68.9 for stock I think the issue is the newer elbow design. You can see it is a plastic elbow with a rubber gromet. The prior elbow was glued to the plenum and was solid. The oem is similar. You see how a tiny space gets created when I bend the elbow. Well as most who have installed a plenum, there is not much slack in the hose. So when you actually get it on, it is actually tugging at the elbow and I believe it deforms the gromet to make a leak. This is the whistling sound I am hearing when I give it throttle. There is no issue with the stock or the previous version because the elbow is solid so even if the hose tugs on it, it can't cause a leak. I am going to ask IND to check with Eventuri to see if I can either get the prior version or modify this somehow.
2011 M3 Sedan
08-25-2021, 08:03 AM | #17 |
Rep 1,055
"You see how a tiny space gets created when I bend the elbow. Well as most who have installed a plenum, there is not much slack in the hose. So when you actually get it on, it is actually tugging at the elbow and I believe it deforms the gromet to make a leak. This is the whistling sound I am hearing when I give it throttle. There is no issue with the stock or the previous version because the elbow is solid so even if the hose tugs on it, it can't cause a leak."
Is this an assumption or have you confirmed? Fill the gap with grease maybe and see if that makes the whistling go away to confirm. It doesn't seem to me that any of the hose fittings are exactly air tight, even in oem form but I could be wrong. From my understanding, the prior solid fitting elbow was made of cf and snapped off in some early iterations. I recently installed the plenum as well and have no whistling. I did use some lube on outer perimeter of the throttle body mounts to help them slide into place.
aFe Stage 2 Intake | BW Race X-Pipe | UUC Corsa Exhaust | Alpine MS Tune | Brembo GT
08-25-2021, 09:43 AM | #18 |
Rep 934
Wow I’ve just paid a lot of money for the plenum and induction kit I hope it fits like OEM as that’s what all the literature says.
Hope I don’t have loads of issues with them |
08-25-2021, 01:24 PM | #19 | |
Rep 427
I used lube for the center openings and open up the clamps more than normal and slid them all in place. Was able to finally tighten all of those areas down. Sounds was coming from the front of the plenum and you can make it go away by pulling back on the elbow to create a better seal. Which is why it does not constantly make a sound. Putting grease there wont help as it will get sucked in. Anyways Eventuri and IND are awesome, they are taking back the plenum to inspect and fix any issues. The tightness might also be from where the elbow is positioned. On some they were positioned too far away so that might also be the issue though my oem elbow feels just as tight with the hose tugging on the elbow when installed but since the oem is solid, no leaks can happen.
2011 M3 Sedan
Blindside_1376755.00 pjk38088.00 |
08-25-2021, 01:26 PM | #20 |
Rep 427
Sorry didn’t take many as that issue was on one of the early ones. Seems like they have not had any issues since.
2011 M3 Sedan
08-25-2021, 02:19 PM | #21 |
Rep 10,603
Wow you have a lot of perseverance. I would have gotten fed up and quit much quicker than you.
Also glad IND is helping you out. Everyone moans about their prices but they sell their service with those prices not just a product. Hope it all gets sorted for you but definitely makes me rethink wanting this setup. |
///M Power-Belgium64686.00 |
08-25-2021, 02:47 PM | #22 | |
Rep 427
IND is awesome, I have been pretty much buying all my stuff through them. They custom painted my brembo BBK, also ordered a new rear bumper from them that matched perfectly. Need to get the front euro bumper from them next…. For the setup, i think i either got unlucky that my car’s tolerances were at the extreme as the factory plenum stretches that hose as well. They have sold a lot of these without issue so I would not hesitate to get one.
2011 M3 Sedan
Blindside_1376755.00 |
