BMW X5 and X6 Forum 2014-Current
      09-02-2021, 05:11 PM   #1
XxBBVTMxX
XxBBVTMxX's Avatar
Drives: 2014 X5 35d, 2008 Lexus IS-F
Just wanted to share my little experiment, which works great for anyone looking to get a media blaster. I couldn't find anyone to do my N57, so I decided to tackle this myself. It is difficult to find the appropriate tubing to modify, but here it is and it is easy to build.
Harbor Freight:
-Media Blaster ($34.99)
-Merlin Air Blow Gun ($6.99)
-Blast Media (use Fine!) ($27.99)
Things around the house:
-Hot Glue
-Epoxy
-any 3 Screws (but must tap after drilling, to tighten properly)
-Drill
Note: you can disconnect the media tube and use the gun as a air blower as well. This way, you can blow out any media lingering around as well.
As for the intake port adapters, Google around. I found the 3D specs for an N57 and just had them printed out.
This tube is the perfect size for getting in those intake ports and blasting (walnut fine). Just wanted to share in case anyone is looking to modify their own. Super easy DIY.
happydude139.50
      02-05-2022, 02:36 PM   #2
XxBBVTMxX
XxBBVTMxX's Avatar
So finally had a change to use my walnut blasting gun on my N57… works like a charm 🤙🏽
Been busy with moving and new job.
https://youtube.com/shorts/pkjNuFdPQX8?feature=share
      02-05-2022, 02:43 PM   #3
XxBBVTMxX
XxBBVTMxX's Avatar
Also, for you guys who want to attempt to do your own walnut blasting, don't waste your time trying to turn the engine manually.
Use an electrical home grade copper wire, gloves and tap the blue and yellow on your starter solenoid until you get your port closed, then knock it out.
Your solenoid and starter sit next to your engine oil drain bolt.
      02-06-2022, 05:44 PM   #4
11_335D
Drives: 2011 BMW 335D
Excellent job! I will have to tackle this soon. How bad was the carbon buildup?
2011 335D sport
2014 X5 35D m-sport
2014 X5 35I luxline
      02-06-2022, 05:51 PM   #5
XxBBVTMxX
XxBBVTMxX's Avatar
Sitting at 106k, it looked gunked-up. But the walnut blasting knocks it all off well. The only area that was a pain was the spot directly above the valve stem. The oil there gets coated so the walnut blasting was doing nothing. Grabbed a metal pick and broke it down, vacuumed the chunks, then walnut blasted and got it no problem.
xbimmers
