09-02-2021, 09:52 PM | #1 |
Rep 1
Addressing Drone at Cruise
Hi all! Just picked up an E92 M3 and loving it so far, but I'm noticing more drone than I would like, most noticeable in 6th around 40-45 MPH anytime I'm using maintenance throttle.
Previous owner installed Turner test pipe and a Corsa cat-back exhaust. If I were to revert/replace the exhaust to eliminate the drone would I likely be replacing the exhaust or the test pipe? I've read that the Corsa system doesn't drone with the stock cats but I don't know enough to say that it's definitely the test pipe. Whole system sounds fantastic when I'm ripping around but I do get a little self conscious when I'm just going about my day. Or does the E92 drone even in stock form and I should get used to it? Edit: Car is MT, so it's not like I'm in sport mode and the car is holding gears longer or anything. |
