09-11-2021, 04:57 PM | #1 |
Rep 70
Engine ticking at cold start
hello everyone, for several weeks I can hear an engine tick for the first few seconds when starting. Sometimes more or less strong and for a longer or shorter time. Do you have an idea of the problem ? My car has 125kkm with a melody without cold start procedure
Vidéo ticking : https://youtube.com/shorts/sWyMrVsll_4?feature=share |
09-13-2021, 09:24 AM | #2 |
Astronaut
514
Rep 732
Are you supercharged?
It's hard to hear the ticking noise, but if you record closer to the passenger/driver side wheel wells, we'd be able to hear it better.
Instagram | @undisclosedm3
"Never think that you are above taking out the trash." |
09-13-2021, 12:26 PM | #4 | |
Friends don't let friends ESS
3224
Rep 888
Drives: '11 Lemans Blue 6mt Harrop e90
Garage List 2011 E90 M3 [9.00]
2003 Porsche 911 Turbo [9.75] 2019 BMW X5 xDrive40i [0.00] 2013 Mercedes E550 ... [0.00] |
continuous high pitched whine that sounds like a supercharger. A continuous and quiet high pitched sound that sounds like a failing pulley bearing And a few seconds of high pitched tapping. That may be the pulley bearing too |
09-13-2021, 04:58 PM | #5 |
Rep 70
I am N / A. the high-pitched whistle comes from my oil pump according to my preparer but does not present any risk. The ticking is not much on the video, looks like a hydraulic lifter. I will make the best video
you can hear it about 5 seconds after booting in the video. sometimes longer |
brady55013.00 |
09-13-2021, 04:58 PM | #6 |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
Pop the hood and investigate the drive belts and all accessories on them. Most likely the tick you hear (I didn't hear) is a worn belt, weak tensioner or failed PS or AC or alt. You would need to pinpoint as we cannot with this video. Have you ever done your belts & pulleys in the past? Pretty easy to do yourself if it's just belts and pulleys.
09-13-2021, 05:06 PM | #7 |
Rep 70
here we can hear also during boot and a few seconds after boot https://youtube.com/shorts/Ds2CqBtS2bM?feature=share
09-13-2021, 08:27 PM | #8 | |
Lord Scrip
1823
Rep 3,018
