09-19-2021, 03:48 PM | #1 |
Rep 334
Is spring compressor needed for ZCP suspension removal?
Anybody know if a spring compressor is needed to take out front oem zcp suspension or will it clear the fender without one? Many thanks!
09-19-2021, 07:52 PM | #2 |
Rep 724
Are you just removing the entire strut? If you aren't loosening the central nut at the top of the strut you don't need a compressor. To remove the strut the bolts/nuts on the edges need to be loosened to free the strut from the upper mount. One would need to have the strut removed in order to get a spring compressor on the strut if you are trying to replace the springs.
09-19-2021, 08:00 PM | #3 |
Rep 1,504
You do not need a spring compressor to remove the shock and strut as one unit. You can probably find a yt about it but it will swing out for removal, just barely. Many people put some tape on the fender just in case to avoid a scratch.
2011.5 E90 M3 DCT ZCP Slicktop
10-17-2021, 11:24 PM | #6 |
Rep 865
Mine isn't a ZCP, but I'd guess it's a pretty similar process?
Chris, 2008 E92 |
10-20-2021, 01:16 AM | #7 | |
Rep 2,167
The E9x and F8x are probably the easiest cars I've ever done lowering springs on. With the wheels off, I can probably swap the springs on each side in 5 minutes. |
shimmy232357.50 |
10-21-2021, 09:29 AM | #8 | ||
F15 daddymobile
2358
Rep 3,535
