09-25-2021, 07:41 PM | #1 |
Rep 176
CarPlay issue - Connection issue
I have the factory installed Apple CarPlay from a 2017 M3 with a build date of 07/16. It doesn't always auto-connect or it's hard for it to find the device. I'm not sure if this is a common issue it just has been getting frustrating. It also doesn't always connect through the menu and says no connection found. I've tried doing hard resets and it will help for a little then next time I go in the car it doesn't work again. Anyone with a similar problem or who knows a way to troubleshoot this issue would be greatly appreciated. Not sure if it's a firmware issue or if it is a common problem in general. Thanks in advance
09-25-2021, 08:57 PM | #2 | |
BimmerPost Supporting Vendor
1804
Rep 3,070
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
09-26-2021, 12:26 AM | #3 |
Rep 176
09-26-2021, 10:46 AM | #5 |
1804
Rep 3,070
If CarPlay is from factory, then it has WiFi antenna fitted.
