09-26-2021, 11:31 AM | #1 |
Rep 483
Blocked Washers Question G11 7
Hello
My jets aren't doing any water. There are three, the first one by the drivers side works but is a bit ... low in pressure, the middle one works less and the far one even less. When I quickly stab the washer activation stalk all three shoot something out - but when I hold the stalk only the first one works and it's quite weak. Done a pin in the hole of each and wiggled the rubber about a bit. Does it need to go in? |
09-26-2021, 11:45 AM | #2 |
Rep 313
Is there any way to disconnect the pipe closer to the washer bottle to see if you have enough pressure at source, that may help with determining if it is a pump issue or a blockage somewhere in the pipe nearer the washer jets.
Also, obvious question, it has enough water in the bottle?
Current: 2018 BMW G11 740d MSport XDrive
Past: 2015 Audi 3.0tdi A8L, 2012 Audi 3.0tdi A8L, 2009 Audi 3.0tdi A8, 2005 Jaguar 4.2V8 XJL, 2000 Jaguar 4.0V8 XJL + many others |
09-26-2021, 09:51 PM | #3 |
Rep 1,618
Drives: '23 760ix; '23 X3; '23 MB wgn
Disconnect the pipe and run some compressed air in it?
BMWCCA
Current: 23 760ix (Carbon Black/Tartufo) (after first one totaled) '23 X3; '23 MB E Wagon Prior: BMWs (3,5,7 & 8 series (2x!)) X3, MB (C, E, and S), Alfa GTV, MGB, Audi (A4, A6), Saab, Volvo, Toyota, Lincoln, Chrysler, Oldsmobile, Chevy, Rambler. |
10-05-2021, 06:21 AM | #5 |
Rep 42
10-05-2021, 08:11 AM | #6 | |
Rep 399
https://bimmertips.com/pro-tip-dont-...d-in-your-bmw/ |
10-05-2021, 10:36 AM | #7 | |
Rep 42
10-05-2021, 12:47 PM | #8 |
Rep 1,487
I was told by an old independent import mechanic that a bit of diluted white vinegar will dissolve any scaling that might be building up in the lines.
The jets on my 2019 have been slow to start spraying as well. I'll give it a try myself and report back.
Blessed Beyond Measure
10-06-2021, 03:17 PM | #9 | |
BMW Miniature Collector!
13835
Rep 8,003
However many dealers refused to honour this as a warranty claim since owners did not use the BMW Screenwash. Costs about £20 for 5 litres so not too expensive.
10-06-2021, 03:55 PM | #10 | |
Rep 209
I get all these from abroad. Never buy fluids in the Uk at Bmw dealers. trust me : different quality ! And from Ebay ?? NEVER!
G11 740xd M Performance
F16 X6 M50D F21 140xi Dark Side: E53 AMG |
