10-03-2021, 09:39 AM | #1 |
Rep 4,554
Drives: 2015 328d xDrive
Rear Fogs/BFD on OLED?
Does anyone know where to find the rear fogs on US-spec CS/GTS cars with OEM OLED tail lights?
And how does brake force display work on US OEM OLED? If at all? |
10-06-2021, 03:26 PM | #3 |
Rep 4,554
His tails aren't OEM. Would like to know if the coding works on OEM lights. US spec, not euro.
10-09-2021, 07:11 PM | #4 |
BTC maxi
222
Rep 1,124
02-14-2022, 01:06 PM | #5 | ||
///M Powered for Life
11517
Rep 10,345
If you're still curious, I can look up track vids where I'm behind a GTS to see what it does |
02-14-2022, 01:19 PM | #6 | |
Rep 4,554
If you have information or videos proving that the US OLED fogs are functional I'd love to see/learn more. Usually US cars employ BFD via the rear fogs but if there are no fogs in the OLEDs then I wonder how the BFD works. Might be that they flash the brake lights or indicators?
SYT_Shadow11517.00 |
02-16-2022, 09:26 AM | #7 | |
11517
Rep 10,345
actually, CanAutM3 might also have access to pictures/videos for BFD on OLED tails working differently, as he's in Canada? Hope that helps |
AndrewC198910949.00 |
02-16-2022, 09:32 AM | #8 | |
Rep 4,554
02-16-2022, 12:06 PM | #9 | |
11517
Rep 10,345
You should connect with someone that can do remote coding though, try SaNGRia as it might be possible to redirect the rear fog functionality to those lights... or make BFD flash those side indicators, or main brake lights, etc. Good luck in your search, keep the community posted! |
AndrewC198910949.00 SaNGRia996.50 |
02-16-2022, 06:09 PM | #10 |
Rep 1,353
Hey there, PM me what needs to be done i will do my best.
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
02-16-2022, 08:00 PM | #11 | |
Rep 20,742
Drives: 2021 911 turbo
It is Almaretto that told me what coding parameter to change to activate the rear fog on the OLED, maybe he remembers. As a tidbit for those that don't know, the guy in the video significantly over complexifies the modding of the switch. No need to remove the vent nor the light switch cluster. Just use a plastic trim removal tool (or a round edge knife with some electrician tape at the end) to pry out the fog switch, it will pop right out. Trim the tabs with an exacto, and pop the switch back into place. A less than 5 min job EDIT: Dug a little, I could only find this thread in which most of us were already involved, but it does not provide more answers: https://f80.bimmerpost.com/forums/sh...highlight=OLED
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 02-16-2022 at 08:28 PM.. |
AndrewC198910949.00 SYT_Shadow11517.00 |
03-02-2022, 04:07 AM | #12 | |
Rep 8,364
https://f80.bimmerpost.com/forums/sh....php?t=1764837 https://f80.bimmerpost.com/forums/sh...&postcount=144 https://f80.bimmerpost.com/forums/sh...g#post27286406 |
05-24-2022, 12:42 PM | #13 |
Rep 4,554
Finally figured this out thanks to DLag30
US Spec LCI F32, F36, and F82 do not have the hardware necessary to code on the rear fogs. This applies to the OLED tails on the M4 CS and GTS as well. You can however repurpose another light to act as a rear fog which is what I did. I used the inner indicator portion but you can also use the outer portion, third brake light, reverse lights, etc. And yes, the indicators do continue to work normally, they simply have an added secondary function now. Coding: FEM -> 3060 -> NSL_Verbaut (Value= Verbaut) REM -> 3063 -> Mapping_Nebelschlussl_L_function (Value=nebelschlusslicht) REM -> 3063 -> Mapping_Nebelschlussl_R_function (Value = nebelschlusslicht) REM -> 3063 -> Mapping_Nebelschlussl_L_output (Value = 00x1A) REM -> 3063 -> Mapping_Nebelschlussl_R_output (Value = 00x1B) Results:
SYT_Shadow11517.00 JAI///M3528.00 |
