10-11-2021, 09:08 PM | #1 |
Rep 215
Road and track coilover rear issue
I purchased the road and track coilover for my 08 e92 m3 and the front were easy but the back is giving me issues. I installed everything following the diagram below and been in contact from the company and all i get is if i followed the diagram it should be good. I keep getting loud clunking noise at any speed over any type of bumps.
my question is why are there 2 versions of the diagram. one with the std washer and one without. i used the one without as told by someone who works as a tech for Ohlin and it clunks, I tried it with the std washer and it still clunks loud. anyone willing to help would be greatly appreciated spent 2 weeks trying to solve this issue. thanks https://www.youtube.com/shorts/c7UEE...?feature=share https://youtube.com/shorts/Q3cxACr2-O0?feature=share Last edited by Angr2387; 10-11-2021 at 09:21 PM.. |
10-11-2021, 10:15 PM | #5 |
Rep 4,183
That seems like an aftermarket rear strut mount? Monroe or Powerflex? Maybe try putting on the stock mounts and try? That said I'm on Powerflex street rsm and no issues.
10-11-2021, 10:18 PM | #6 |
Rep 215
the guy from ohlins told me to get this because its better than stock. im going to try the stock mounts on weds. i got another mechanic coming weds as well to diagnose it.
10-11-2021, 11:12 PM | #8 |
Rep 215
just ohlin tech he said if i followed the diagram everything should be working . idk weds i hope the mechanic has more answers. ill put the original bushing and see if any luck
10-12-2021, 07:51 AM | #9 |
Rep 2,028
This looks correct. Make sure the poly bushing actually went up into the hole and is seated correctly. Tighten the upper mount with the car on the ground.
The clunk is likely from the LOWER mount. I just installed Ohlins dedicated track and had that issue. I upped the torque on the lower bolt to ~90ftlbs and the clunk went away. The lower A-ARM pinches on the bushing with more torque thus preventing the bolt from rattling against the interior bushings bore. The interior diameter of the bushing bore seems to be machined a hair too big. |
Angr238738.50 |
10-12-2021, 11:58 PM | #12 |
Rep 215
fml i bought the bushing press 250$ from ecs and 6 mins in the rod breaks and it didnt even take my bushing out just broke whatever inside and leaving the outer in. i have a dermel any other suggestions ?
10-13-2021, 11:28 AM | #14 |
Rep 215
we had a prior issue where the ball joint had to be slightly cut to make it fit in the control arm one side always kept sitting on the control arm uneven so we slightly shaved a little to make it fit flush in the control arm.
10-13-2021, 08:01 PM | #15 |
Rep 215
https://youtube.com/shorts/zrNk6XoVDqk?feature=share
https://youtube.com/shorts/nHC19jgr-fM?feature=share so my mechanic says the ohlin moves and has play cause the bushing in the shock is too small compare to the oem i purchased this from fcp euro and i bought it back in june 15 and past the 90 days to return will reach out to them to find a resolution and also will reach out to the ohlin tech and show the videos above |
10-14-2021, 12:50 PM | #16 | |
Rep 2,028
10-14-2021, 12:51 PM | #17 |
Rep 215
yeah my kit was missing the top nuts smh . makes sense i appreciate it i called fcp euro and all that now ill call back asking for these washers. but weird the directions in the kit never mentions washers going there.
thanks again |
10-14-2021, 01:01 PM | #18 |
Rep 2,028
Your kit came with instructions?! lol mine had none but there were two baggies... one with conical washers for fitting front end-links since they are round... and one with metal sleeves/washers that tighten up the lower mount in the rear.
Angr238738.50 |
10-14-2021, 01:05 PM | #19 |
Rep 215
all i got were the washers on the rear shocks to avoid bottoming out. the instructions saying not to remove, or can cause bottoming out.
i got top adjuster knob and the tool to adjust the spring height and thats all i got. first i realized my oem top nut didnt fit was too big so he sent me 2 nuts (pause lol) than now i realize more shit was missing so frustrating because the directions dont mention these washers. it would of made the whole troubleshooting easier. appreciate it i sent brian a email hes out till monday and they dont pick up any calls all days not even sales. i sent fcp a email as well. almost coming to a end thank God 🤝 appreciate the help |
bbnks21212.50 |
11-03-2021, 09:59 PM | #20 | ||
Rep 269
///Mobbin1478.00 |
11-04-2021, 10:53 AM | #21 |
Rep 2,672
So I just swapped springs on my car and am getting a clunking noise as well, didn't have it before the swap, I did change ride height also. Wondering if I did something wrong. Car is at the shop, will report back.
Also wanted to share the e9x m3 specific instructions that came with my kit:
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
derbo3612.50 |
11-04-2021, 10:55 AM | #22 |
Rep 2,672
Also wanted to mention that I'm running the AKG upper shock mounts from 3DM as well, no clunking before I swapped springs and adjusted ride height.
