10-16-2021, 02:17 PM | #1 |
Rep 977
Increased emissions + SES
Trying to see if anyone has dealt with a similar issue, every couple of weeks my SES light and increased emissions warning pop up on the car, checked the code and got a misfire in cylinder 7, but the car is not misfiring at all. I come from the N54 world so I'm very very familiar with misfires
If I clear the code it's gone for a few weeks then comes back. I ordered some spark plugs + coils just to knock them out anyway, but I'm not sure that's gonna fix the issue since the car drives exactly the same with or without the SES and emissions warning (nice and strong). I've read through other threads with the emissions warning and SES, but nearly all of them noted a difference in drivability or going into limp mode, which thankfully I'm not experiencing. Appreciate any helpful advice, thanks! |
10-16-2021, 02:39 PM | #2 | |
Rep 25
Let us know the result. |
10-19-2021, 06:17 AM | #3 |
Hey, where have you been all my life?
684
Rep 1,400
I've had the exact same issue forevaaa
It could be failing primary cats, bad O2 sensor/s, stuck secondary air pump, bad plugs. What mods are you running? Any exhaust mods? How old are the plugs? |
12-29-2021, 02:33 PM | #4 |
Rep 977
Hey man. Stock car, actually just changed the plugs to see if that would fix it. Car runs super smooth but I'm still getting the increased emissions + SES with a code for a misfire in cylinder 7. Haven't been driving the car much so I really wanna get it solved asap. You ever figure out what it was?
12-29-2021, 02:39 PM | #6 |
684
Rep 1,400
I'm fairly certain the cause of this is a very minor exhaust leak.
Apparently there is a common leak that develops at the doughnut flanges that connect the mid pipe. I didn't even realize mine was leaking (and even passed smog with it), but it finally got worse and worse to a point where I could hear it louder and louder. Finally it got progressively worst in one day of driving that the care went into reduced power mode ("limp mode"). I've not had time to replace it yet due to holidays, but plan to do so in the coming weeks when I get home. |
12-29-2021, 02:41 PM | #7 |
684
Rep 1,400
If you're a DYIer, take a long rubber hose and use it as a stethoscope (check near the mid pipe and under the heat tray near the headers).
If you prefer to take it to a shop… Have them use a smoke machine to smoke out the leak. |
12-29-2021, 03:02 PM | #8 | |
Rep 977
I did get limp mode once but that seemed to be from a misfire before changing the plugs. |
12-29-2021, 03:08 PM | #9 |
684
Rep 1,400
I didn't even realize it was a leak either. The smog tech told me I have a leak, but passed it anyway since the check engine light wasn't on at the time.
Tall tale sign will be if you get the increased emissions message once you get the engine really warm and/or under some spirited driving. The metal expands under heat and increases the size of the leak. The leak was very, very undetectable. Turns out it is very common, and many people have this leak. |
12-29-2021, 03:29 PM | #10 | |
Rep 977
atopa2002204.00 |
12-30-2021, 08:43 PM | #11 |
684
Rep 1,400
Yup, I got misfires before the leak finally got really bad, and the individual misfires were accompanied by a random cylinder misfire code as well (and limp mode - reduced power kicked on).
02-01-2022, 02:33 PM | #12 |
Rep 977
Update: taking the car to a shop on Monday to get a second opinion. Had someone look at it and they are learning towards a failed valve spring, really hoping that is not the case.
Confirmed it is not O2 sensors after checking them with the ISTA software. Will have the shop perform a smoke test to check for any undetectable exhaust leaks. Anything other than valve spring failure will be good news to me lol. |
02-03-2022, 09:57 PM | #13 |
684
Rep 1,400
Curious to know what yours turns out to be. Please update here when you find out!
Ubersmooth315.50 |
02-04-2022, 09:54 AM | #14 | |
Rep 550
How old is your battery, is it on a tender? |
02-04-2022, 11:23 AM | #15 | ||
Rep 977
It is not on a tender. I'll see if I can borrow a tool to check the voltage on the battery and see if it needs to be replaced before I drop the car off. Would be a nice easy solution if that was the case |
02-04-2022, 12:30 PM | #16 | |
Rep 550
I had increased emissions pop up when my battery was low, I never found out if this information was accurate, but I read that since the battery is ingrained to the computers that when it gets low, it deprioritizes certain modules. As an example your comfort access doesnt work when your battery may be low. I never confirmed if that was actually true though. |
02-11-2022, 12:19 PM | #17 |
Rep 977
To update the thread: it turned out to be an ignition coil. When I originally swapped the coil, the code did not follow. Ordered a new coil that ended up being defective, and after swapping that one around the code followed it. Headed to the BMW dealer last night and paid the tax to get a new one. Swapped it in and all is well again.
Scrippy1823.00 |
