11-05-2021, 08:49 PM | #1 |
Driver
2692
Rep 2,714
2011 E90 Slick Top 6MT single hump Track Build 69k miles
2011 E90 M3 Jet Black 6 speed manual Slick top No navigation (i.e. "single hump" dash), no option car except heated seats originally 69k miles Clean title in hand I am the second owner, and I purchased it at 13,800 miles. I daily drove it nearly stock until starting to track it in the late Spring of 2019. It has been very reliable, and I've always done the obvious things like warm-up gently and change the oil regularly with the oem oil and filters. I've driven it hard on track, but never wrecklessly. It has never been spun in my entire ownership, which is a good testament to how easy it is to drive fast, given that it was my first track car. I'm selling to try some different things (including open wheel maybe?…). It is almost certainly the fastest four door at the tracks up in this region, and it is still street registered and driven to every track day. The car is very well known at The Ridge and Pacific Raceways and with the region’s PCA community, particularly by owners of some very fancy machinery, who are always bewildered by the speed and reliability of this four door BMW. Ridge Motorsports Park lap time: 1:43.8 on used Pirelli DH 285's on 10" wheels, and 1:45.5 on 295 Yokohama A052 (A052 only run a couple times there for Global Time Attack, though). Pacific Raceways Lap time: 1:25.4 on used Pirelli DH 285's on 10" wheels (this was in the hottest part of the day and traffic played a significant roll all day, so even faster would've been possible in the morning). The car has been entered in three time attack competitions: Global Time Attack at The Ridge 2020: 2nd place Limited Class Global Time Attack at The Ridge 2021: 2nd place Limited Class Ongrid Ridge Wars 2021: 1st place Race Class Some track videos of the car... https://www.youtube.com/user/kevin41288/videos Mods below, with install date in parenthesis. Wheels -18x10.5 ET25 Titan T-S7 (forged) Iridium Silver square (Spring 2021) Brake mods -PFC Z54 front BBK (Spring 2020) - PFC 11 pads -PFC Z45 rear BBK (Spring 2020) - PFC 11 pads Drivetrain mods -OS Giken Superlock 1.5way LSD with custom tuning (Spring 2021) installed with Diffsonline full rebuild kit and all new seals and o-rings, and only run with OS-250R -Core4motorsports Ultimate Press-in Studded Hubs: 14mm Core4/MSI: 75mm Front & Rear (Summer 2020) -New oem wheel bearings all around, and new upgraded hubs with core4motorsports stud install (Summer 2020) -RTD V4 Race shifter with DSSR (Spring 2021) -Revshift 95A engine mounts (Spring 2021) -Revshift 95A transmission mounts (Spring 2021). Will include the oem transmission mount and shifter if you would like to switch back to oem style to avoid all of the NVH that stiff transmission mounts bring Suspension mods -KW Clubsport coilovers with 628lb/in front springs and 1120lb/in rear swift springs (Spring 2019) -Turner solid aluminum subframe mounts (Summer 2017) -Bimmerworld solid aluminum differential mounts (Spring 2021) -Hotchkis front and rear sway bars (Spring 2021) -SPL front sway bar end links (Spring 2021) -Hotchkis rear sway bar end links (Spring 2021) -GAS monoball front tension arms (Summer 2020) -Bimmerworld inner camber arm spherical bearing kit (Spring 2021) -Lemforder spherical bearings for all rear trailing arm bushings (Spring 2021) Safety mods -425 Motorsports custom fabricated weld-in half cage (Spring 2020) -Schroth Flexi 2X2 FHR 2020MY harnesses (Spring 2020) -Sparco Circuit II QRT 2020MY driver seat (Spring 2020) -Sparco Evo II QRT 2019MY passenger seat (Summer 2019) -Brey Krause driver and passenger direct floor mounts with sub strap bars (Summer 2019 and Spring 2020) Aero/exterior mods -APR GT-250 67" wing (Spring 2020) -Singular wing end plates (Spring 2020) -POM GTS1 front carbon lip (Spring 2020) -APR carbon fiber front splitter (Spring 2020) chassis mounted sealed to lip and bumper -Faircloth Composites carbon fiber splitter venturi tunnels (Spring 2020) -Racebred spats (Spring 2020) -Trackspec center hood vent (side vents included)(Spring 2020) -N15 fender vents (Spring 2020) Engine and exhaust mods -Macht Schnell Stage 2 Intake (2017) - comes with two filters -Active Autowerke test pipes - (Spring 2016) -BPMsport Stage II tune (Spring 2016) -Corsa exhaust (Summer 2017) -Bimmerworld Power Steering Reservoir (Summer 2020) Other mods -Interior largely stripped, but stereo, speakers, A/C, center console retained -trackdaydoorcards.com door cards -Euro MDM retrofit, but I only drive it with DSC off Other replacements/maintenance -New oem power steering pump (Summer 2020) -New oem driver side rear wheel carrier and axle (Summer 2020, with the Core4 hub upgrade because they were seized together) -New oem passenger side rear axle (Spring 2021) -New Bosch battery (Spring 2020) -New spark plugs each season -PS fluid flushed each season -Diff fluid flushed each season with OS Giken fluid only -Oil and filter changed after the equivalent of 3-4 full track days
E90M 6MT Slicktop Single Humper in need of a diet
11-08-2021, 12:28 PM | #5 |
Rep 1,504
Service details on RB's, TB's, Valve Covers? I kind of assume these things have been addressed for such a sorted car but may help check a few more boxes for potential buyer.
Would be curious to see what this thing would bring on BaT. Haven't seen any like this there. GLWS OP!
2011.5 E90 M3 DCT ZCP Slicktop
11-08-2021, 11:59 PM | #6 | ||
Driver
2692
Rep 2,714
As for the rod bearings, I’m not in the extreme hysteria group, and am always a bit worried about having a perfectly running engine disassembled and reassembled in any way, but I intended to do them within the next year. However, I’m not going to do them if selling. Gives the next person the option to choose their own anyways, since everyone has their opinion on which shells and bolts to use. I don’t have any experience with BAT, so your guess is as good as mine. I was under the impression that BAT catered more to show/collector cars than track builds though.
GeoK104.50 |
11-09-2021, 01:45 AM | #7 | |||
Rep 1,504
Bartledoo2691.50 |
11-09-2021, 12:40 PM | #8 |
Driver
2692
Rep 2,714
Thanks for the idea. I’ll definitely look into and consider it if I don’t get any interest locally.
06-09-2023, 11:33 PM | #12 |
Driver
2692
Rep 2,714
I love it too! Never had, and probably never again will spend as much happy time with a single car.
07-14-2023, 12:57 PM | #16 |
Driver
2692
Rep 2,714
I made a aluminum frame for the lower splitter to give it rigidity in the central section, and mounted the frame to the chassis. Then I just bolted the splitter, lip, and bumper together. I removed them all as one piece when necessary. It wasn’t too difficult.
