11-29-2021, 02:49 PM | #1 |
Rep 400
FS: M4 GT4 wheels & R888R tires
Hey Folks- I'm parting out my F80 track toy and have a few parts available. Everything just came off the car this weekend so I'll be cleaning it all up and adding pictures. Located in Fremont, CA, not looking to ship the heavy / large stuff. No need for trades as the car is going back to stock.
Also have studs & spacers available:
11-29-2021, 04:08 PM | #2 |
Rep 726
Drives: E46/F15/GT4
How hard was it to get those M4 GT4 wheels to fit on the F80?
11-29-2021, 04:20 PM | #3 |
Rep 400
12-06-2021, 11:12 PM | #4 |
Rep 717
12-07-2021, 03:32 PM | #8 | |
Rep 400
12-08-2021, 10:59 AM | #10 |
Rep 24
Any estimates of how much on all the supporting mods in order to put these wheels on? Really tempting to replace my ze40 with this set to fit some 295s up front
12-08-2021, 11:28 AM | #11 | |
Rep 3,611
If you can find a GTS aluminum spindle, then you can apparently run the in front directly: https://f80.bimmerpost.com/forums/sh...&highlight=gt4
Current: F80
Prior: F82, F32 |
12-08-2021, 02:45 PM | #12 | |
Rep 400
RugbyBro7609.00 |
12-29-2021, 11:25 PM | #13 |
6586
Rep 5,305
Are the SPL Lower Control Arms, Tension Arms, and Tie Rods able to achieve this? Do the SPLs specifically allow you to shorten the geometry, or do they only lengthen from OEM?
01-04-2022, 02:27 PM | #14 |
Rep 400
You can shorten, or lengthen, the SPL parts from OEM spec. In order to make the setup work the way I wanted, I ended up using a 1” shorter dogbone for the tension arm, and a e9x LCA (just the aluminum arm part, which is ~1” shorter than the F8x version). The tie rod end worked as-is.
EGbeater116.50 |
09-15-2023, 11:33 PM | #15 |
Rep 507
Drives: M4 GTS
Did these wheels ever sell?
