12-16-2021, 03:38 PM | #1 |
Rep 399
Turbo lifespan and rebuild
Howdy, folks.
I'm whipping a 2013 F13 with 52K lovingly driven miles, only about half of which have been put on by me over the last 4 years. I'm fanatical about oil changes, and I do a Blackstone test at each seasonal change... yes, I do a change every 3-5k miles per year, at the end of each season so old oil doesn't sit in the crank for the 4-5 months the car is garaged over the winter. So far, every test has come back aces. Recently, after replacing a valve cover gasket at a dealership on their recommendation, I've heard a 'tapping' noise coming from the engine bay. It's not audible when the car is cold, only after the engine gets to operating temperature. I won't tell you the potential horror story that the dealer presented, but a quick diagnosis from an indy suggests that it might be the turbo bearings starting to go. Is this to be expected? I'm given to understand that the S63Tu is one of BMW's more reliable engines and turbo failure doesn't seem to be one of the characteristic flaws like rod bearings on the V10 or torn subframes on the E46, so I'm kind of surprised. If the indy is right, what options would you recommend? I'm seeing turbo rebuild kits for as little as $60 each, which would seem the most cost-effective remedy, but please share your thoughts. What say you? |
12-16-2021, 03:43 PM | #2 |
Rep 77
Is the car tuned? Do you have video of the “tapping”? It is highly uncommon for turbo failures on these cars and these motors but anything is possible it is a M afterall lol. The worst case scenario would be a bent rod or rod bearings……. a video would be fantastic.
Wheel man1443.00 |
12-16-2021, 03:49 PM | #3 |
Rep 399
Bone stock that I know of, other than a Meisterschaft exhaust. I'm the second owner, but after multiple visits to the dealership, nobody has said anything about a tune.
I'll try to capture a video tomorrow... |
12-16-2021, 04:00 PM | #4 | |
Rep 77
A video would really help, take it easy on the car till you come to the source of your problem just my 2 cents |
12-16-2021, 06:11 PM | #5 |
Fueled by Recycled Dinosaurs!
644
Rep 1,179
Drives: F06 M6
I've been through an engine and tapping noise is something that reminds me of rod bearing. Get us some video/audio as it help but be mindful not 100% accurate.
Maybe have the oil and rod bearings tested/inspected.
2015 F06 M6 Silverstone Metallic II, Individual Full Leather, B&O, Night Vis, CCB, RKAutowerks (CP Rods/Pistons, DI Cams, CF Intakes, Coated DP's & Billet Diff Brace), InfinityAuto Turbo Inlets, Mishi Oil Cooler, JB4, XHP S3, BM S3
12-17-2021, 09:03 PM | #6 |
Rep 399
Went for a drive today with the intent to grab a video, and surprisingly enough, the sound wasn't nearly as bad as previous. Not sure how this factors in, but I did an oil change at the dealership not 100-ish miles ago. Waiting for the sample results to come back from Blackstone. I'll re-post if the sound reappears. Stand by. ..
TinCanSailor644.00 |
12-20-2021, 11:06 AM | #7 | |
Rep 187
12-20-2021, 02:25 PM | #8 |
Rep 399
Not sure, I'll have to check with them. Is 5-30 too heavy for the S63Tu?
12-21-2021, 12:12 PM | #9 |
Rep 187
12-21-2021, 10:16 PM | #10 |
Rep 632
Drives: 2014 M6 Grand Coupe CP
Although 5-40 is an acceptable alternative for warmer weather areas, there is little to support that 5-50 is of any benefit for a healthy engine. There are "internet engineers" and there are engineers that specify the oil viscosity based on requirements of the design.
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination |
12-29-2021, 08:29 AM | #11 |
Rep 277
Drives: 2014 M6 Gran Coupe
Was the tapping noise different when the engine was under a load vs decelerating? Different at idle vs at varying RPM?
Other than during differences in engine oil temperatures; Wrist pin and rod bearing noises in motors usually don’t go away on their own. Valve train components and injector noises often do. As for your oil analysis, keep in mind the bearings in the S63Tu are not typical, and are made of a ‘non-lead’ alloy.
2014 M6 Gran Coupe-Alpine White/Blk
2015 740i Sapphire Blk/Blk 2018 Tahoe RST 6.2 2019 Porsche 911 Turbo 991.2 |
