11-23-2008, 10:24 PM | #1 |
Rep 2,244
BMW Performance Accesories - carbon ceramic brakes coming?
Check out this teaser video BMW released:
http://www.bmw.com/com/en/owners/acc...e_3/start.html Seems to me those are carbon ceramic brakes on the car. If they are going to have them for the regular 3 series, I am sure we will have them available for the M3 soon. Thought it was interesting. * EDIT * : Seems BMW took down the orignal video, looking for a mirror. Mirror: Last edited by Sticky; 11-23-2008 at 11:16 PM.. |
11-23-2008, 10:59 PM | #2 | |
Rep 1,597
Drives: MY2022 X5 M-Sport 45e White
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked. |
11-23-2008, 11:11 PM | #3 |
Rep 2,244
I paused it and zoomed in to take a closer look, it looks like a carbon ceramic rotor under the light. I guess maybe it isn't, oh well, still nice to speculate.
11-23-2008, 11:29 PM | #4 | |
Rep 1,597
I would be just happy to get any sort of brake option for the M3!
11-23-2008, 11:36 PM | #5 |
Rep 2,164
Drives: 2020 BMW 330i xDrive
I will find out!
Former BMW Client Advisor
11-23-2008, 11:45 PM | #6 |
Rep 48
Nope they look like normal upgraded brakes.
Go to the following link and scroll down and click on 'Braking System': http://www.bmw.com/com/en/owners/acc....html?cat=1008 Heres the text from that link: "Braking system* The BMW Performance braking system is designed to facilitate a sporty driving style. The six-piston aluminium fixed callipers and grooved, cross-drilled discs give drivers an incredible amount of control, even in the wet, while their low weight reduces the unsprung mass of the car. Calipers painted in BMW Performance Yellow are a striking visual feature. For detailed information please contact your BMW partner." |
11-23-2008, 11:51 PM | #7 |
Rep 256
That car looks/sounds amazing! Can't wait to see what they come up with for the M3! Good game BMW! Well done!
EDIT: The seats were swapped out for race seats. Can we say weight reduction? BMW may not be making the CSL, but it seems like they are at least making the parts that would have been used in it available. I'd venture to guess that those seats would reduce at least 75lbs. The brakes and wheels might reduce weight too and that's not considering all the carbon fiber pieces that are shown. Something over 100lbs of weight reduction seems likely with the performance parts. Very cool!
11-24-2008, 12:03 AM | #8 | |
Rep 2,244
Here is to hoping we see carbon ceramics from BMW performance. |
11-24-2008, 12:26 AM | #9 |
Rep 6,107
11-24-2008, 12:49 AM | #11 |
Rep 2,244
11-24-2008, 01:07 PM | #12 |
Rep 10,407
There is no way I would hold my breath for CC brakes for the M3. The rotors are just way too expensive. Most of what you get from CC rotors is just longer life and weight reduction not really improved braking distances nor fade resistance.
11-24-2008, 05:28 PM | #13 |
Rep 9,034
You guys aren's seriously excited about the BMW performance brakes for the 135/335???
They're smaller than your stock brakes. The only advantage is the nice looking calipers. Besides, would you really want this to happen: Here's the thread: http://www.1addicts.com/forums/showthread.php?t=18453
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
11-24-2008, 05:55 PM | #14 | |
Rep 8,033
http://www.supercarmovies.com/html/interface.html
11-24-2008, 05:57 PM | #15 | |
Rep 8,033
11-24-2008, 06:16 PM | #16 |
Rep 1,597
Judging from the picture they got hot, real hot, damn hot!
11-24-2008, 11:33 PM | #17 | ||
Rep 9,034
It appears a racing team had some race pads custom cut for the caliper. Then they destoyed two sets of calipers one of which was loaned to them from another racer!! The guys who loaned them his calipers said he used the stock pads and KILLED them, but had no problems with the piston's falling apart. There are a lot more pic's in that thread. Quote:
And a follow-up thread showing the piston's taken out of the caliper: http://www.1addicts.com/forums/showt...453#post277453
11-25-2008, 01:25 AM | #18 | |
Rep 10,407
Brake pads need to have properties that are tailored to the temperatures they will see. In this regards track pads have it easy as they often only have to work well warm to hot, maybe just hot only depending on the track. Street pads are obviously different. Of course the pad is developed to match the rotor in terms of friction, wear and material transfer but the rotor material is not the magic - it is the pad. So again CC rotors provide: decreased weight, increased lifetime and great resistance to warpage from heat. Fade is caused by pad and/or fluid problems. Assuming the pads were properly matched to the rotors and that both systems were adequately cooled and all else was apples the apples fade should be similar. So in conclusion I would simply bet the pads were not up to the task. They were surely different pads but I'd say different but not equal. |
11-25-2008, 06:09 AM | #19 |
Rep 137
Swamp,
Not meaning to disagree, but a lot of the alleged advantages of ceramics (namely longevity and resistance to warpage) have not been borne out in practice for some manufacturers at least. Carbon ceramics are not the be all end all that they are made out to be. Look at Porsche. Huge problems with rotor life, ironically when tracking which is supposed to be the environment they are designed for. Lots of horror stories of carbon rotors cracking after 2-3 track days. Loads of Gt3 owners have [down?]graded to steels, due to this issue and then re-fit the carbons when selling the car. Alcon in particular, offer an aftermarket rotor that works with the OEM pistons that come with the ceramics, just for this issue. That coupled with the fact that the replacements are hard to obtain and cost a fortune, means that IMO they are for bragging rights only. Mick |
11-25-2008, 07:12 AM | #20 | |
Rep 8,033
I personally haven't done any serious research on ceramic discs, so I don't have a position.
11-25-2008, 03:59 PM | #21 | |
Rep 10,407
I have heard some horror stories about these brakes rotors. It could be manufacturing issues, quality issues or a variety of other factors. I don't think it is the norm though, but that is mostly a guess. Do you think it is truly the norm? I do believe the material is an amazing one and it has been used very successfully in aerospace brakes, racing brakes and other tortuous industrial applications. There are always some growing pains when switching from very well understood materials in specific applications to very different materials for the same application. Many industries experienced a lot of growing pains moving from metallics to composites (like cabon fiber) for structural applications. This switch will have some of the same growing pains. |
11-25-2008, 04:02 PM | #22 | |
Rep 10,407
