12-20-2021, 01:29 PM | #1 |
Rep 26
Help -- Sounds like blown sub, but it is not
Hey all, thanks in advance....I'm at a total loss on this one.
2015 M4, with the HK sound system. Factory sub woofer on drivers (left) side sounded blown. Classic motor-boating sound for base instead of a crisp clear signal. Ordered the bavound ghost subs....installed and powered up....Now i'm getting the exact same blown sub sound on the bavsound sub. I swapped the left / right subs and confirmed that it is specific to the left side placement and not the sub itself. I then went back and tried both the factor subs in the right side and left.....All 4 subs sound blown out on the left side and are fine on the right. Question -- what/how do I check next? Anyone else experienced something like this? Thanks! |
12-20-2021, 01:44 PM | #2 | |
Rep 2,181
12-22-2021, 08:37 PM | #4 |
Rep 2,181
Water damage will look like a blown woofer… water gets into the OEM amp, either causing short circuits or oxidation of contacts in the PCB, damaging the amp circuitry. You may not see any watermarks on the outside of the amp chassis, but the water will be inside of it.
12-26-2021, 09:37 AM | #5 |
Rep 290
Whether damaged by water or not, the problem is definitely originating with the amp. Your best bet is to find a used (known good) amp as a drop in replacement. Many on here who have upgraded from the HK system should have used ones for sale.
'17 i8 Protonic Red Edition; '17 “30 Jahre” M3
'90 Z1 Red w/red/black leather, GC coilovers, Alpina Dynamic DS-02 '91 850i Mauritius Blue/Black, BBS RS-GT '85 M635CSi Alpine w/buffalo; '03 M3 Conv, Imola ‘85 323i Baur; ‘02 X5 4.6is Estoril; ‘95 Racing Dynamics K30.4 |
12-26-2021, 08:02 PM | #6 |
Rep 2,181
You would want to know if there is a water leak in the trunk so the replacement amp may be damaged as well.
01-02-2022, 08:11 PM | #7 |
Rep 290
Of course that would be prudent. There are many things that can cause a factory amp to go belly up, though, and water intrusion in a BMW that is less than 10-years old is, IMHO, very unlikely.
01-02-2022, 08:40 PM | #8 |
Rep 2,181
In my professional experience, water-damaged OEM amps are more prevalent than any other fault. OEM amps are quite durable otherwise.
