12-30-2021, 11:23 AM | #1 |
Rep 1,322
Questions re: potential clunk/knock from swaybar/endlinks
Hey all, appreciate any input here.
I have a '17 ZCP (stock sway and endlinks), with the B16 Damptronic kit paired with Vorshlag camber plates (these were installed about 10 months ago, and impact gun top nut tightening was done as per Vorshlag instructions), with a fairly mild drop. I've developed a front clunk/knock going over bumps. I'm worried it could be related to camber plate bearing issue (though they haven't been on the car that long), but want to cast a wide net. I've never dealt with changing out swaybars or endlinks, so am trying to figure out if that could be an alternative cause. What makes me think that it could be more in that area is that over harsher bumps at times I can feel the clunk transmitting to my feet. Also, I can hear something occur when the front end "twists" like when the car first crosses from my street onto my inclined driveway. I took off the front wheels and with my hands tried wiggling the bar and the 2 endlink ends, and couldn't clearly induce any play. Nothing visibly looks awry. Does that exclude any problem, or perhaps some issues but not all (like an issue with the bar bushings themselves)? Would the next best diagnostic step be simply disconnecting the endlinks on both sides and seeing if noise goes away? If so (dumb question), I assume I would disconnect at the bar? I've watched Farkle's endlink swap video so seems straightforward enough. Thanks much |
12-30-2021, 10:21 PM | #2 |
Rep 3,549
IME top mount/camber plate noise is pretty clearly felt/heard from the top of the engine bay.
It's possible to have a loose enough end link to create noise, but not so loose that you easily feel it when going under the car like you did. This is because there can be load on the bar/end link even when the car is in the air. I would just grab the appropriate socket and tighten all the end link nuts first to see if any of them are loose. I think it'd be less likely that the bolts securing the end link brackets came loose (especially if you've never swapped the stock bar out).
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
jfritz271126.50 |
12-31-2021, 09:43 AM | #3 | |
Rep 1,322
The sound itself is a bit tricky, at times I think it could be more from topside but honestly I'm not sure |
12-31-2021, 02:02 PM | #4 |
Rep 471
You can also disconnect the links from the sway bar and hang them out of the way with zip ties, then drive the car and see if the noise goes away.
If it does, that was your issue. If it doesn't it's something else. Sway bar links can make a lot of noise and sound like something much larger when they go bad. They're like the squirrel in the woods that sounds like a deer. |
jfritz271126.50 |
01-04-2022, 07:33 PM | #5 |
Rep 145
Is it more pronounced on the drivers side?
I had a similar thing happen when I first fitted my MSS springs (Which are height adjustable). Seemed more pronounced on the front right (Drivers side here in AUS). Under a hard bump (only at higher speed - usually a pothole or something like that), it was hitting the bump stop, raising the car a bit seemed to fix it. |
jfritz271126.50 |
01-05-2022, 07:42 AM | #6 | |
Rep 1,322
This past weekend when changing to winter tires I did snug up just the endlink bolts at the damper (they didn't seem loose), but no change in noise. When I have more time I'll take belly pan off so I can get at the bolts at the bar, and while I'm there be sure that all other arms are snug, and check the subframe bolts as well. May have to consider Racer20's steering gear clunk as well (though no noise noted when rapidly turning steering wheel back/forth with car stationary) |
01-29-2022, 08:40 AM | #7 | |
Rep 115
jfritz271126.50 |
01-29-2022, 04:34 PM | #8 | |
Rep 1,322
Since previous post I tightened the steering gear a bit (probably less than most from what I've read), and perhaps slightly better but still there. I may go a little more. Subframe bolts seemed tight. Waiting on my front SPL endlinks; if that doesn't do it then it's probably the plate bearing |
