      01-02-2022, 02:38 PM   #1
Jaber
Drives: Bmw 135i 2009
Tire rubbing
Hi…
I have a bmw 135i 2009 and I have a wheel rubbing problem as I did rear
Fender calibration and front fender rolling but still rubbing so the wheel setup is
ESR wheel 18 8.5 30 offset for front and rear all are the same size
Rear tire 255 35 18
Front tire 225 40 18
Stock OEM suspension
So could you guys help me for a rubbing soloutions I would appreciate��
      01-04-2022, 10:20 AM   #2
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Originally Posted by Jaber View Post
Hi…
Rear tire 255 35 18
You need more offset. Around et45 or run a 235 all around with lots of camber.
      01-04-2022, 01:03 PM   #3
Jaber
Thank you .. So is there a way to make the offset from et30 to et45..?
      01-04-2022, 02:35 PM   #4
PRTSB1M
Drives: AW3 1M
No, you can go from higher offset to lower offset with a spacer, only. You need the opposite of a spacer, which is most likely a different wheel with higher offset.
      01-04-2022, 02:41 PM   #5
HP Autosport
Drives: F80 M3
No, you can not. You will need new wheels.
1addicts
