01-17-2022, 06:47 PM | #1 |
Rep 795
Ohlins rear spring rubber seat going out of place?
Recently put on a set of Ohlins, front is great, but the rubber seat for the rear springs kept on going out of place....some part of it will get pushed out and the upper spring holder is making contact with the car's body.
Does anyone else have this issue? Any heavy duty/more molded replacement for the one that came with the Ohlins?
2011 BMW E92 M3
2018 Tesla Model 3 Long Range RWD Last edited by W12x; 01-17-2022 at 07:10 PM.. |
01-17-2022, 07:59 PM | #2 |
Rep 2,747
Yep mine too are torn up… I believe it's only purpose is to prevent the perch from chewing up the anti weather chassis insulation, if it was too substantial it would make the rear end feel vague and spongy? Just recenter them if you can remember every time you unload the spring.
9ers
01-24-2022, 04:51 PM | #4 | ||
Rep 795
I'm having the crazy idea of CNC/cutting a custom rubber piece not only to go on top of the perch like the stock Ohlins, but also to wrap around it. Attached a really bad MS Paint illustration of this crazy/dumb idea... 1 is the original Ohlins rubber seat, this is simply not much height sticking out on top of the spring perch for the rubber seat to hold onto. 2 is what I'm thinking about, let the thickness of the rubber seat remain mostly the same on top, where the perch and chassis makes contact, so it wouldn't make it vague and spongy(can also add a tiny bit of thickness and use a harder rubber for durability) then have the rubber go around hugging the lower part of the spring perch(should be very minimal impact on handling since this part is not making hard contact with vehicle body) so it will 'lock' into place
2011 BMW E92 M3
2018 Tesla Model 3 Long Range RWD |
01-24-2022, 05:33 PM | #5 |
Rep 248
01-24-2022, 05:47 PM | #6 | |
Rep 795
2011 BMW E92 M3
01-26-2022, 03:13 PM | #7 | |||
Rep 795
https://shop.bcracing-na.com/product...solator-rubber Ordered a set for $29 shipped and will update if they fit or not
2011 BMW E92 M3
09-26-2023, 01:52 PM | #8 | |
Rep 258
-Thumbie
2011 Jerez E90 M3 6-speed Competition Package |
11-07-2023, 02:28 PM | #9 |
Rep 258
FYI I talked to my shop about this and they suggest using a thrust bearing
I am having the R&T kit installed next month and will report back on how that goes.
-Thumbie
11-07-2023, 11:26 PM | #10 |
Rep 2,824
Similar to the Swift thrust sheets that 3DM recommends. I have a pair and my R&T kit is silent.
https://3dmmotorsport.com/products/s...hrust-sheets-1 |
Thumbie103.00 |
