01-30-2022, 10:33 PM | #1 |
Rep 578
Water Injection Troubleshooting/Testing (water not being consumed)
I just got back from my 3rd track day in the GTS and am now confident that it is not using any water at all.
I topped off the water tank when I bought it in October 2021 and after the first two track days thought it odd that I didn't need to add any water, however were are no errors popping up and didn't see anything with my code scanner. Also I always hear the pump purging the lines after I shut it down, it runs for about a minute so I figure the pump is ok. I also changed the stone filter about a month after I got it and there were some white deposits on the old one so I cleaned out the housing and installed the new one. I know it doesn't run when below 41* but it's been warmer that at the track. Also I haven't seen the digital power gauge above 420 so it's clear it isn't working. I'm wondering, aside from taking it to the dealer, if anyone has figured out any methods to test the system or has had the same issue? I'm thinking there might be a clog somewhere but thought I' ask before starting to take it apart. I'm out of warranty and prefer to work on the car myself rather than leave it at my local dealer. Thanks in advance |
01-31-2022, 12:49 AM | #2 |
Rep 411
AFAIK everyone who has had those symptoms has taken it to the dealership and they replace the valve block with supposedly an updated version. I didn't compare any model numbers when mine was done, but I know they ordered the valve block and it took a bit to arrive from Germany. I suppose you could pull the valve block out and see if there is obvious corrosion inside. Or take it to the dealership and hope for a goodwill replacement, as it does seem to be a defect in the GTS.
01-31-2022, 11:02 AM | #3 | |
Rep 578
01-31-2022, 11:42 AM | #4 |
Rep 1,396
I had the block replaced by the dealer last summer for the same reason. Even though I had the extended warranty, it was not covered. They ended up replacing it anyway since I have had a good relationship with them but had to pay the taxes on the parts. Came out to around $400 instead of over $ 3,000 for the whole job.
I believe a lot of people have had those replaced. Definitely an issue. Worth it for peace of mind… |
01-31-2022, 02:02 PM | #5 |
Rep 24
Put the car in M-Display mode looking at horsepower. Go out somewhere on the highway where you won’t get in trouble. Drop it down a gear or two and floor it. If you see around 500HP the water injection is working. If you see more like 450HP it’s not working. I didn’t think mine was working, but this test proved that it was.
JustAnothaM4891.50 |
01-31-2022, 02:07 PM | #6 | |
Bored at work....
893
Rep 5,397
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
01-31-2022, 02:23 PM | #7 | ||
Rep 578
01-31-2022, 03:32 PM | #8 | |
Rep 1,266
Drives: 2016 M4 GTS
2021 X5M Comp Marina Bay Blue
2016 M4 GTS Alpine White 2005 M3 Comp Interlagos Blue Instagram: @JustAnothaM4 Last edited by JustAnothaM4; 03-23-2023 at 02:12 PM.. |
mikerunt326.00 |
01-31-2022, 03:47 PM | #9 |
///M Powered for Life
11517
Rep 10,345
It would be easier if there were a mark at '500'. Instead we have like 420 and 560 or whatever they are and you have to guess where 500 should be. It's not easy to do this while WOT...
JustAnothaM4891.50 daveishi244.00 |
02-01-2022, 06:47 PM | #10 | |
Rep 578
The 2nd reading is a little less than halfway between the 420 and 560 marks. If we consider the middle to be 490, then it is possible I'm reading at around 470-480? Very odd, that doesn't seem like a car that isn't consuming any water but that is indeed the case, and somehow I'm right in between 450 and 500. |
03-06-2022, 01:35 PM | #11 | |
Rep 1,404
Tomorrow i will ask my friend at the bmw store if the replacement is covered. Anyone know if it can be encoded in some way so that the system activates at a lower temperature? |
03-06-2022, 05:22 PM | #12 |
Rep 190
FWIW, I've found that I need to change the filter every two events (4-5 track days).
IG: SpecGTS
SYT_Shadow11517.00 |
03-08-2022, 03:29 PM | #13 |
Rep 578
How did you find that out? ie What were the symptoms? I replaced mine as soon as I got the car and have another spare but clearly replacing the original didn't do anything, about 5 track days in now.
03-10-2022, 09:38 PM | #14 |
Rep 190
I've replaced it three times at this point. Either it was throwing the error that there wasn't enough water in the tank or it wasn't using up water. Every time it was highly calcified. It's very easy to check yourself if you haven't already. IMO I'd try that first since it's an easy DIY and only $40 that you can reuse. Otherwise it sounds like you'll have to replace the block
IG: SpecGTS
03-11-2022, 08:57 AM | #15 |
Rep 72
Regarding the filters, in a pinch I’ve soaked them in CLR and then rinsed several times with distilled water. Solved my not using water problem when I couldn’t get a replacement before a track day.
03-11-2022, 04:44 PM | #16 |
Rep 123
I am just going to throw in my quick input as to the usage of the water injection system.
I recently went to Big Willow raceway last weekend and the temperature was below 40*F when I drove out there in the morning. I did 4 20 minute sessions throughout the day. I saw the my first session did not have very much water usage. the water level was near the plastic seam near the top. The second session it may have dropped about a 1cm more. however on my third session, The water level went to about half way, a definite noticeable drop. I may have video to see the M-Gauges but I cant confirm yet, I generally run Tire Temp Display. A couple of things to consider is that the water system is only used when you are above 5000 RPM and FULL Throttle, Not 6800 RPM and 80% throttle (Nor Full throttle pedal input but 85% ECU Throttle due to DSC/Traction interference). Also the GTS boost goes from the 17 PSI found on M4C to about 21-22 PSI boost. That's fine by itself, but you have to understand that the water is there to reduce the intake temperature, make air denser and cooler... which then allows to operate continuously at higher boost with out the possibility of knock or pre combustion. Unfortunately we can not see intake manifold temps easily and see what the ECU is determining. Its considering Boost, Throttle, Air Temp before it initiates water injection to say the least. If Air is in the ideal temperature range within the intake manifold/post intercooler while at full boost/full throttle, then why add water right? |
03-13-2022, 01:16 AM | #17 |
Rep 17
03-13-2022, 11:31 AM | #18 | |
Bored at work....
893
Rep 5,397
See page 46 https://f80.bimmerpost.com/forums/at...9&d=1463413166
03-14-2022, 02:00 AM | #19 | |
Rep 17
schnell325892.50 |
03-14-2022, 08:42 AM | #20 |
Rep 1,404
03-14-2022, 08:55 AM | #21 |
11517
Rep 10,345
how did you update the software? At the dealer?
03-14-2022, 02:20 PM | #22 |
Rep 1,404
