02-03-2022, 02:26 PM | #1 |
Rep 85
Bimmercode F85
Looking to code a few things into my car, but curious what others have done? What are your favorite things that you coded with bimmercode? Thanks!
02-03-2022, 03:07 PM | #2 |
Rep 1,233
Following
Just bought Bimmercode and haven't touched a thing. Also interested to know what is possible and popular/favorite features.
02-03-2022, 04:32 PM | #4 |
Rep 1,038
I've only done some basic, from memory.
I did try to set the low fuel range warning a little lower, but that appears to break blind spot monitoring and still does not work. Last edited by Chilled; 02-03-2022 at 04:41 PM.. |
02-03-2022, 11:02 PM | #5 |
Rep 60
the one that I'd recommend the most is lowering the speed at which the BSM light turns on, I set mine to 20km/h. I have dark tint and at night it really helps.
02-04-2022, 08:16 AM | #6 |
Rep 352
You can also activate your door handle guide lights when reverse is engaged. Cool feature imo!
Also, unfolds side mirrors at a specific speed threshold.
2016 BMW X5M F85 | 2019 - Present
2015 BMW X5 F15 5.0i m-sport | 2016-2019 2001 BMW X5 3.0i Sport | 2005 - 2008 |
02-04-2022, 01:29 PM | #7 |
Rep 213
To many to list off the top of my head but some that was coded so far that I rememberr:
-Different color ambient lighting -Angel eyes 100% Brightness -Disable warning chime -Brake force display -Auto/Remote folding mirrors -Door handle guide lights on reverse -turn signal on HUD -Soft close trunk -Video in motion
17 X5M || 08 PS2 335xi
02-04-2022, 06:39 PM | #9 |
Rep 7,584
Just an FYI…their website lists supported coding options for the f15 & f85. You can go directly to the site and click on each heading and you’ll get a list of all the supported coding options for that particular module. So one can simply go through the list and jot down the things that interests them: https://www.bimmercode.app/cars/f15/
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
Upurock47.00 |
02-04-2022, 08:06 PM | #10 |
Rep 340
Drives: Several
Garage List 2004 Ferrari 360 Sp ... [0.00]
2015 Ford F150 Lari ... [0.00] 2015 Porsche GT3 [0.00] 2017 BMW X5M [0.00] 2020 BMW X7 M50i [0.00] |
Can someone explain what and how video in motion is and how it works. I’ve activated mine but not found a use for it? Maybe because I have RSE? Anyone with RSE that has been able to code the rear screens to match id6 lite?
02-04-2022, 08:48 PM | #11 | |
Rep 85
02-04-2022, 09:28 PM | #12 |
Rep 293
Put video files on a usb flash drive and plug it into the usb in the center console. Select usb on the media list and enjoy!
02-04-2022, 10:34 PM | #14 |
Rep 868
VO coding the volume of the confirmation sound, that is played when locking/unlocking the car, to "VERY HIGH" gets a lot of heads to turn......and slightly annoying for my my neighbors every morning and evening....on purpose...
02-04-2022, 11:54 PM | #15 | |
Rep 2,719
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
I’d also recommend coding the tailgate to soft close— that prevents it from slamming.
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
02-05-2022, 05:35 AM | #17 |
Rep 175
Don't forget to do Foglights stays on when High Beams are engaged
Blue By You631.00 |
02-05-2022, 10:47 AM | #18 | ||
Rep 293
02-05-2022, 03:22 PM | #19 |
Rep 7,584
Yes…that is an EXPERT MODE coding parameter. And I believe the coding parameters are different based on build date. The early model years 2014/15/16 have a different coding versus the 2017/18…so make sure you find the correct coding parameters.
The tailgate slam (recode) was one of the most satisfying changes. EDIT: Here’s a link to a thread on BimFest that has the coding parameters for the 2014-2016 & the 2017-up tailgate “thunk” coding. Scroll down to the last post (#6) for the 2017-up coding parameters: https://www.bimmerfest.com/threads/h...thunk.1403573/
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 02-06-2022 at 03:36 PM.. |
Upurock47.00 |
02-05-2022, 10:49 PM | #20 |
Rep 2,719
Drives: M3
As the guy above me said/ one of my fav changes too!!!
02-06-2022, 04:18 PM | #22 | |
Rep 293
slow_roll109.00 |
