BMW X5 and X6 Forum 2014-Current
      04-25-2022, 10:26 AM   #1
BimmerNewb79
Drives: 2015 X5M
New to X5M, help please.
I bought a '15 F85 close to a month ago, I'm daily driving it. Dropped the wife off at work this morning get back home park it in the garage. Go back to it bout 20 mins later and all kinds of codes and won't start. I have a MHD wifi obd adapter and use it for monitoring and codes. I've got an optima/agm charger on it, putting in 12.1V and about 12 amps, but the battery voltage doesn't seem to be going up. I haven't found any blown fuses yet, but not sure I'm looking in all of the right spots.
Anyone have any leads to help me out?
Details:
38000 miles
KW V3
Unknown to me catless dp
Valvetronic exhaust
Unknown to me tune
XDelete (for 2wd)
Codes:
- DME active codes -
138104 - Exhaust flap, activation: Line disconnection.
1B5101 - Terminal 15_3, line from CAS, electrical: Short circuit to B+.
- DME shadow (inactive) codes -
1B2304 - EWS-DME message incorrect Timeout.
1FB101 - Check Control message (ID 229): Vehicle battery charge low!.
- DME #2 (slave) active codes -
- DME #2 (slave) shadow (inactive) codes -
140011 - Misfire: Fuel injection deactivation.
- Transmission active codes -
None
- Misc. information -
4/25/2022
MHD version 3.81
Voltage 12.1 V
Last flashed file : Unknown
VIN: 5YMKT6C59F0C89263
Factory software:
HWEL 184F v003_019_005
BTLD 1242 v003_089_001
SWFF 10CA v089_110_001
SWFF 2495 v089_110_136
Current software:
CAFD 0B0A v000_042_003
Current PRG (hex): 10CA596E01
ECU build date: 2015.03.04
ECU status: -
- Readiness -
Misfire: Complete.
Fuel System: Complete.
Components: Complete.
Catalyst: INCOMPLETE.
Heated Catalyst: Not avail.
Evaporative System: Complete.
Secondary Air System: Not avail.
A/C Refrigerant: Not avail.
Oxygen Sensor: INCOMPLETE.
Oxygen Sensor Heater: Complete.
EGR System: Complete.
Flash counter: 2
      04-25-2022, 11:03 AM   #2
9vapors
Drives: CB X5M
When the battery is dead, or close to it, all sorts of things like this happen… I'd start with the battery. Do you have the soft close doors? Are they working? When the battery is losing charge it will start to prioritize things, one of the first to go is the soft close doors…
Ive also seen folks had to change out the cables to the battery, possibly need that based on the code.
      04-25-2022, 11:08 AM   #3
BimmerNewb79
Drives: 2015 X5M
Soft close still working on and off the charger.
      04-25-2022, 11:15 AM   #4
9vapors
Drives: CB X5M
Wouldn't think it's the battery then…
      04-25-2022, 11:24 AM   #5
9vapors
Drives: CB X5M
You mentioned having downpipes etc, I just did this this weekend and found with some things after it was all done… the grounds from the DME weren't connected, and contact with the DME was not working. Can you check to make sure one of those grounds aren't damaged or something there? They are on a bolt at the base of the plastic wire holder that crosses over your turbos. Would be on the left side of it, at the rear bolt location…
      04-25-2022, 12:11 PM   #6
BimmerNewb79
Drives: 2015 X5M
Confirmed the bolt is tight and there are 2 terminals on that bolt.
      04-25-2022, 12:25 PM   #7
BimmerNewb79
Drives: 2015 X5M
Disconnected both batteries. Aux battery measures 12.8v, main battery measure 12.6v.
No date found in the main battery.
Video added
      04-25-2022, 01:04 PM   #8
BimmerNewb79
Drives: 2015 X5M
New symptom. Car is now completely off, but main battery is metering 13.4v and aux is reading 12.9.
      04-25-2022, 03:10 PM   #9
M3jamaica
Drives: 2008 e92 m3
I hope u solve it easy....just like u I'm about to buy a used x5M and I'm so scared of stuff like this, i have been hesitant for this reason.....
      04-25-2022, 03:11 PM   #10
musa
musa's Avatar
Drives: F86, E92, E53, E39.
Have you verified the batteries are fully charged and no loose or deteriorated connections? From my experience, all these symptoms are typical of low battery charge.
      04-25-2022, 04:45 PM   #11
BimmerNewb79
Drives: 2015 X5M
I've worked on my own GM trucks for years, and know them pretty well, but wanted something different with performance. I'm capable to work on it, just don't know anything bout them really. The price tag doesn't help with getting into a new platform.
      04-25-2022, 04:52 PM   #12
BimmerNewb79
Drives: 2015 X5M
Which connections would you suggest?
      04-25-2022, 05:18 PM   #13
9vapors
Drives: CB X5M
Battery connections in the trunk, red cables and brown on the secondary…
musa424.00
      04-25-2022, 06:48 PM   #14
BimmerNewb79
Drives: 2015 X5M
Got car to power up back to the original problem. Ground on the main battery didn't make a good connection when I put it back on. Main battery at 13.9v now, but can't connect to the dme with mhd obd wifi adapter. 🤦
9vapors653.50
      04-25-2022, 08:12 PM   #15
BimmerNewb79
Drives: 2015 X5M
Replaced main battery, load tested okay but, it was date codes 2015.
New discovery is the obd port doesn't have any power. Is there a fuse for that?
      04-25-2022, 09:45 PM   #16
9vapors
Drives: CB X5M
I think it's 11, 12, 18?
      04-26-2022, 08:47 AM   #17
BimmerNewb79
Drives: 2015 X5M
I have confirmed that the obd works, and mhd says it is flashing the dme back to stock successively.
Radio/ idrive, hvac, headlights, front protection systems are all still throwing inop status. Car won't start either.
I ordered ista and an enet cable(should have tomorrow). Bimmercode won't connect currently.
      04-26-2022, 09:12 AM   #18
9vapors
Drives: CB X5M
Geez dude, DME is screwed?
      04-26-2022, 09:45 AM   #19
BimmerNewb79
Drives: 2015 X5M
God I hope not.
      04-26-2022, 08:34 PM   #20
Cbozz
Cbozz's Avatar
Drives: M3
God I hope not.
Bad battery
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
      04-26-2022, 09:05 PM   #21
9vapors
Drives: CB X5M
God I hope not.
Bad battery
He replaced the main one…
      04-26-2022, 09:35 PM   #22
Chilled
Chilled's Avatar
Australia
371
Drives: F85 X5M
You mentioned that the charge was not taking. Where you charging via the engine compartment points, and how where you measuring that it was not charging?
If via engine, have you tried to replace the IBS cable?
*EDIT*,
BTW, you should be able to connect ista with the MHD adapter. That thing is just a wifi hotpsot. You may need to change a few of the settings.
xbimmers
