04-27-2022, 12:18 AM | #1 |
sportscars only
![]() 3300
Rep 3,219
How to add engine oil? HELP A NOOB
I dunno my way around an engine, so please help me out. Most of the time I notice that my engine oil level is at MAX but on some rare occasions it drops to a bit below MAX but then on my next drive it goes back to MAX. I've heard of some of our cars burning oil, having leaks, and maybe I had that prb before w the oil filter housing but I fixed that long ago, so overall I never had any real issues re the oil level.
However, I recently saw that my level is now between MIN and MAX, so I'm losing oil somehow, either by it burning or a mild leak? My tech said just to put in 500ml if it goes below MIN. I'm not due anytime soon for an oil change, so what's your advice? I'm using Liqui-Moly 5W40, so do I have to buy exactly that or any 5W40 oil will do? Is it as simple as just waiting for a cool engine, opening the cap, putting a funnel and pouring the 500ml in? TIA.
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
04-27-2022, 02:13 AM | #2 |
![]() ![]() ![]() ![]() 159
Rep 474
I usually dont add any oil before message pops up. When it does oil level is at MIN and i just pour a small bottle of oil in. After that its at max again.
My oil level stays at max for a long time, but before my yearly oil change, like a month before i sometimes get a message to add oil. So after 6000-7000 km i have to add some. When i drive less than that i dont have to add anything and just do my yearly oil change. I have had oil filter housing leak, rear main seal leak, valvecover gasket have leaked aswell. But these were not big enough to affect oil level in a meaningful way imo.
2009 35i DCT Havana brown with ivory white interior. Mods: Cobb stage 1+FMIC, Wagner EVO1 FMIC, BMS DCI, KW V3 suspension, M3 front control arms, Hardrace RTAB, Michelin Pilot Sport 4S tires.
tranquility3300.00 |
04-27-2022, 07:35 AM | #3 |
![]() ![]() ![]() ![]() 496
Rep 518
First, keepin' it real, you admit you don't know your way around an engine. You don't even know how to check oil. But you were sparring with Robbi about the rooftop. Yeah, that's precious. LOL
Anyhoo ... oil expands and slips and gets tossed around the block. Checking with cold vs hot engine will have different readings. I like to check oil with a hot engine. (Perhaps wrong, though.) My reasoning is that the oil is there to lubricate a hot engine. It should be at the right level (between MIN and MAX) with a hot engine. So I wait for the engine to be hot, turn off, wait 10 minutes for the oil to settle, then measure it. Preferably you want to add the same brand and spec. But any brand with the same spec will do. In a pinch, any motor oil is better than no oil. Absolutely DO NOT run your engine with low oil. If it's below MIN, than you can add a full litre. If in between, add 1/3 of a litre, wait 5 minutes to settle, measure, repeat. Whilst there's some margin of error, try not to fill above MAX. My trusted indy sent an oil sample to Blackstone Labs. The results were really bad. We're now on a 6-month interval. The next change in August. We'll see what it looks like.
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
04-27-2022, 01:25 PM | #4 | |
sportscars only
![]() 3300
Rep 3,219
Anyway, you'd know since you have a Z4 that we don't have a real dipstick and the E-one checks it when the oil gets warm/hot, that's not the prb and I know how to 'check it', I'm just confirming the filling procedure just in case it's something tricky like replacing the radiator fluid.
04-27-2022, 01:54 PM | #5 |
Rep 474
I dont believe that when oil level message pops up you have to stop your engine immediately. Yes ,sure, dont go on a long drive, roadtrip etc. But im sure this message is designed with some safety buffer in mind. Theres surely some foolproofing margin there.
Message says to add 1L of oil as soon as possible. Its not saying stop, turn off engine or anything like that. When i get this message i usually just drive to the nearest parts store or shop and buy my 1L of Castrol and its full again. I have done that maybe 3-4 times during the 6 years i have owned my car and all is still ok. By adding 1L when message pops up i have never been able to overfill it. By the way if you happen to overfill then a message pops up saying "oil level too high" aswell. I think checking oil level like every week, if its bit below max then proceeding to add 100-200ml of oil to it is a bit obsessive and overkill isnt it? But sure, it doesnt hurt. Also there this in owners manual: "The engine oil consumption is dependent on driving style and conditions." Its normal for the oil level to go down. In my opinion N54 is rather conservative oil consumer. Used to own multiple Honda Civic Type R-s with K20 engine. These engines were designed to drink oil while in VTEC/ higher cam profile was engaged. So if you enjoyed revving it out (which was the whole point of K20), then you had to add oil often. I even carried an extra 1L bottle in the trunk just in case. Thats how ordinary it was with these engines.
04-27-2022, 02:05 PM | #6 | |
sportscars only
![]() 3300
Rep 3,219
04-27-2022, 04:07 PM | #7 | |
![]() ![]() ![]() ![]() 90
Rep 745
04-27-2022, 04:13 PM | #8 |
sportscars only
![]() 3300
Rep 3,219
It's a hassle (for me), I never bought a bottle on my own, I just tell the shop to do my changes.
04-27-2022, 09:47 PM | #9 |
Rep 518
Quick question. Are you in your teens?
Attached an excerpt from the owner’s manual. The measurement (on my car) is from inside the cabin. Same tips from above.
04-28-2022, 02:26 AM | #10 | |
sportscars only
![]() 3300
Rep 3,219
Also, your posts aren't very helpful, I know how to read the levels, just wanna know how to fill it properly. Anyway, here's what it said exactly in the manual, but, hey, what do I, BMW, all the techs and manager know about that? I'm big enough not to wanna diss the guy even though he brought up the issue and then decided to discuss no more haha OK whatevs, I know my way is the better way, he can risk all he wants. "Just sayin' and keeping it real."
04-28-2022, 08:04 PM | #11 | |
![]() ![]() ![]() ![]() 1732
Rep 897
Drives: BMW Z4 M40i, BMW X5x40i
You can easily check for leaks. The one you really want to watch for is the oil filter housing (OFH). It's on the front of the engine and is a known problem area. When it leaks, oil will run down the front of the engine and destroy the serpentine belt at which point really bad things can happen. Oil pan and main seal leaks are easier to check from underneath the car. But to be clear, I've had leaks at the OFH and at the oil pan and the leaks weren't significant enough to cause low oil warnings. If it gets near MIN, just add oil. Use what you normally use. The owner's manual gives you options. Preferred oils will meet BMW spec LL01 or LL01FE. To add it, just pour it in. If the oil level is at MIN, 1 US quart/1 liter should bring it up to MAX. Don't overfill - adding 500 ml is acceptable. Gerry
2023 Z4 ///M40i Thundernight Metallic/Cognac Vernasca/Moonlight/Shadowline/19" Black 799M/PP/DAP/ACC/HK
2022 X5 xDrive40i Phytonic Blue/Cognac Vernasca/DAPP/LSP/PP/CCP/PAP/20" Style 738/Spare Tire/Trailer Hitch |
04-28-2022, 08:17 PM | #12 |
sportscars only
![]() 3300
Rep 3,219
^Tx, Gerry, OK, I guess it doesn't matter if the engine is hot or not, but I'll try not to fill when just finished driving to be safe.
04-29-2022, 03:44 AM | #13 |
Rep 474
In owners manual, if i remember correctly, was written to check oil with warm engine.. for example after 10min drive.
04-29-2022, 03:48 AM | #14 |
sportscars only
![]() 3300
Rep 3,219
That's correct but I'm confused because don't we all have the e-dipstick? We can't manually check since there's no actual dipstick, so I just use the computer to tell me the oil level and that only happens when the oil is sufficiently warm enough, otherwise there's no reading but a 'clock' symbol.
