04-30-2022, 06:05 PM | #1 |
Rep 118
Drives: 2017 bmw x5m, 2018, 540xi
2020 x5m wheels on 2017 x5m help!
I have a set of used 2020 x5m wheels I think it's the 809m which comes with 21 front and rear 22. I want to put them on the x5m 17'. I was toll to used some spacer but not sure which one. I also think the bolt pattern is different. Have anyone done this or could give me a hand would be much appreciated thanks. I also haven't try to put them on yet I just got them today
Kiwto
05-01-2022, 10:42 AM | #3 |
Rep 118
Yea I knew that but I'm trying to find a spacer adapter to run it but there so much. I don't know which one to go for.
Kiwto
05-02-2022, 06:44 AM | #4 |
Rep 175
Don't want to be a Debbie Downer here.. Given how much our X5 weigh and the amount of torque being applied to the wheels (big heavy wheels too), wheel adapters don't come across as being safe. You are better off getting them redrilled or just get new wheels altogether.
P111593.00 |
05-02-2022, 07:55 AM | #5 |
Rep 1,252
Agreed, this is why I didn't go with the newer wheels. They're pretty easy to get a set of and seem to be cheaper for some reason, but the change in bolt pattern is a killer.
05-02-2022, 08:02 AM | #6 | |
Rep 118
Kiwto
05-02-2022, 09:14 AM | #7 |
Rep 7,584
You need to shop for or talk to vendors that sell spacers and give them your wheel's specs (old & new). As already mentioned, the F95 X5M has a different wheel bolt pattern (5x112) and a different hub size (I believe it is 66.6 mm).
The F15/F85 has a 5x120 wheel bolt pattern and a 74.1mm wheel hub. If you want to mount F95 wheels on a F85...then you need to consider what the offset & width of the f95 wheels are vs the f85. If they are the same or similar...then you need a thin wheel adapter/spacer that won't change the wheel offset that much...but will fit the smaller center bore of the new wheels as well as mount onto the larger wheel hub of your f85...as well as take care of the different wheel bolt pattern. Again, you need to know (as well as the person helping you) the wheel specs of each set (width/offset/hub size/wheel bolt pattern)...then select a wheel spacer/adapter that will accommodate and adjust for the differences.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 05-02-2022 at 09:32 AM.. |
Kiwto108.50 |
05-02-2022, 09:24 AM | #8 |
Rep 1,252
EZAccessory 2 Billet Wheel Adapters 5x120 to 5x112 Thickness 1 Inch https://www.amazon.com/dp/B07KSKH5QC...Z2JBWYTSDH0270
Something like these, I think ECS sells them as well |
Kiwto108.50 |
05-02-2022, 12:00 PM | #9 | |
Rep 118
Kiwto
05-02-2022, 04:06 PM | #10 | |
OEM CSL Whore
1255
Rep 1,476
9vapors653.50 |
05-02-2022, 04:29 PM | #11 | |
Rep 7,584
For example...if you mount a wheel that has a 40mm offset & 38mm offset...a 20mm spacer would make the final offsets 20mm & 18mm. This will also push the wheels out further toward the fender. Will the above push your wheels too far out (past the fender)? That's one thing you'll need to be careful with (unless that's the look you're going for). You can use the following site to play around with the wheel & tire specs of the sets of wheels you have and see if adding a 20mm wheel adapter (remember to subtract the width from the original wheel's offset) will stick out too far...or make it. Compare each wheel & tire set up for each axle between the original and the new wheel setup (along with using the wheel adapter calculation to get the final offset. www.willtheyfit.com
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
Kiwto108.50 |
05-16-2022, 02:11 PM | #12 |
Rep 118
So I got some custom spacer/adapter and manage to install the 809m wheels. Basically you looking at a 20mm all around. Looks really good if you ask me would of prefer maybe a 15mm at front but still. Got a little video on Instagram if you want to see, same name on there.
Kiwto
slow_roll109.00 |
05-16-2022, 02:22 PM | #14 |
Rep 118
Unfortunately I didn't take any. I took them off they have some curb rash that are getting fix. But the front stick out about half inch probably less. The rear just looks amazing though no complain there.
Kiwto
06-24-2022, 05:28 AM | #17 |
Rep 118
Finally got a chance to put them back on for the summer. Here a few pictures to finish the thread lol. These look really good on my f85m with the adapter. I'm actually selling these for the G series X5. It's too much work for me to put those wheels on lol.
Kiwto
