05-03-2022, 09:24 PM | #1 |
Rep 32
What’s your lowest KW V3 settings?
I’d love to get as low as possible on the KW’s and have at least a couple threads showing up front. I keep reading the max lowering height is 29.5” from fender to ground. Is that a set measurement from somewhere, even with a couple threads left or is that a recommended max setting from KW?
I’ve seen some X5M’s or X5’s in general which looked lower than that almost down to the top of the tire and would like to have the same stance without sacrificing any premature wear by going outside the recommended specs. Or take my chances if the risk is minimal. Appreciate any guidance from those with experience on this setup. Thanks Current stance: Last edited by Deckdout2; 05-03-2022 at 09:43 PM.. |
05-03-2022, 09:33 PM | #2 |
Rep 4,118
Ground to Fender is always depends on the tire diameter.
V3 ist that low unfortunately, H&R VTF is a bit lower. There's a company providing a low V3 version but you're limited because of rear axle bags. |
05-03-2022, 09:46 PM | #3 | |
Rep 32
BTW, I’m running 295/30/22 up front and 335/25/22 in the rear. |
05-04-2022, 12:07 AM | #4 | |
Rep 4,118
35mm which is close to 1.4 inch is the maximum. Last edited by LOW4LYF; 05-04-2022 at 12:22 AM.. |
09-08-2022, 08:47 PM | #5 | ||
OEM CSL Whore
1255
Rep 1,476
09-25-2022, 09:12 PM | #6 |
Rep 1,030
My buddy and I installed my KW V3 this past weekend. She still needs an adjustment to raise the passenger side. For some reason with same measurements the passenger side always sits a touch lower. For the front I only having 1 ring, but likely will come up a ring or 2. As for the rear we measured 63.5mm since it’s in the safe range in KW directions. So far very happy with the ride and comfort!
JD |
09-28-2022, 03:21 PM | #8 | |
Rep 1,336
I unfortunately use my SUV as an SUV so I can't go low low |
JDE92M3874.00 |
09-29-2022, 10:40 PM | #9 | |
Rep 1,030
JD |
09-29-2022, 10:46 PM | #10 | ||
OEM CSL Whore
1255
Rep 1,476
09-29-2022, 10:55 PM | #11 |
Rep 1,030
09-29-2022, 11:09 PM | #12 |
Rep 1,030
Let me double check again when I’m down there. Made the mistake of not writing it down because of how simple the process is. But now I wish I did for this situation lol. But I attempted one that was provided on the forums. And at my ride height it handled roads well, but jarring roads got too stiff. Made small
adjustments and it’s already damn near perfect at my ride height. So one more fine tuning and I’ll give you the final numbers. JD |
daytonaviolet1254.50 |
09-29-2022, 11:21 PM | #13 | |
OEM CSL Whore
1255
Rep 1,476
09-29-2022, 11:46 PM | #14 |
Rep 1,030
09-29-2022, 11:49 PM | #15 | |
OEM CSL Whore
1255
Rep 1,476
- 21 x 9.5" F et20 275/40/21 Pirelli P Zero - 21 x 11" R et13 315/35/21 Pirelli P Zero |
09-30-2022, 09:25 AM | #16 |
Rep 1,030
