05-11-2022, 02:34 PM | #1 |
Rep 45
Apex Arc-8 figment question
Hi, can anyone tell me if apex arc-8 with 25et fit on 2019 M4? The wheels were on an E46 M3 and hoping to fit them on '19 M4.
Thanks in advance |
05-11-2022, 03:01 PM | #2 |
///M Powered for Life
11511
Rep 10,342
They will fit, but not very well. It's aggressive in the back but as long as you don't do a super wide tire you'll be fine
The F8X really wants a ET36 fitment if you want to go square with wide tires |
05-11-2022, 03:04 PM | #3 | ||
Rep 45
I have 275/35/18 Hoosiers on there with a square setup. So no spacer required? Thanks |
05-11-2022, 03:29 PM | #4 | |
11511
Rep 10,342
Up front you may need a spacer to clear suspension etc, but it's not likely |
cjet683.00 |
05-11-2022, 07:20 PM | #5 |
Rep 535
Drives: 18%E2%80%99 M3 Comp Pkg
I went through this with my apex Arc-8's
I have 19x10 25 et in the rear What exactly is your rim width not sure what apex offers in an 18 in , there's a lot of room , yes does it depend on tire and ride height yes. I was super hesitant on the wheel size and offset once I got it on the car I was not concerned at all anymore . Now if you low… again different story
2010 Apline White 135i - Sold
2018 Mineral White M3 /// Comp Package |
05-11-2022, 11:25 PM | #6 |
Rep 257
I dont see why you would have any issue. The apex f80 fitment guide shows 18x10 25 as the base square setup for tracking.
I have a set of EC7 with f80 offsets and widths already. Just got an E46 and getting a et25 setup that i can also share with my f80. Ive been pretty set on this being the best of both worlds with et25. Havent heard otherwise. https://support.apexraceparts.com/hc...-Fitment-Guide "Front & Rear: 18x10" ET25 Available in: ARC-8, EC-7, EC-7R, EC-7RS, FL-5, SM-10, VS-5RS Popular fitment"
'16 F80 M3 DCT
TC Kline coilovers and camber plates, Apex 18" EC-7, Conti ECF 295r/275f, monoball thrustarms, SPL toe arms, Powerflex diff bushings/bracket, AP Racing 9660, Project Mu H21, Spiegler brake lines, AA midpipe, VTT crankhub, VRSF charge/j pipe, Turner tray, BM3 CS Youtube: Driver407 |
05-12-2022, 09:33 AM | #7 |
Rep 45
fitment of 18x10 et25 on F82 M4
I can confirm that Apex ARC8 18x10 et25 DO NOT fit on F82 M4. The barrel of the wheel will not clear the calipers.
These are ARC8's from about 2010-2012 and I heard from APEX that they increased the barrel in later models so they will clear the calipers. Thanks for everyones input. |
05-21-2022, 06:21 AM | #8 |
Rep 535
Being that they are 18 in correct they will not they just released an 18 in arc-8 that has the improvement to fit I don't believe anyone knew you were referencing an 18 in wheel set up
06-15-2022, 10:49 PM | #9 |
Rep 341
The newer ARC-8 18" clears the iron brakes & calipers well. If you go 18x10 et25 you will need a 5mm spacer to clear the shock up front, rear fits perfectly.
