05-28-2022, 09:25 PM | #1 |
OEM CSL Whore
1255
Rep 1,476
Updated my h&r spacers from 15/20mm to 20/25mm and really like the outcome. Change is very minimal but noticeable. Also want to thank Ben from RGSport for the quick advice and service.
10
HJ478.00 blown99196.00 musa424.00 blackoutF15350.50 islandman21.00 Slickrick2211.00 x6m_bxny212.00 pulubesy39.00 Surgx572.50 r33_RGSport13122.00 |
05-28-2022, 10:25 PM | #2 |
Rep 1,252
Nice, I went the same route and have a similar look. I love it, looking great!
daytonaviolet1254.50 |
05-29-2022, 06:35 PM | #3 |
Rep 901
Looks amazing! What do the X6M folks with 21 wheels use? Anyone?
05-29-2022, 08:59 PM | #4 |
Rep 38
05-29-2022, 09:09 PM | #5 |
Rep 38
I'm using 20mm all around but I think 20mm rear and 15mm front would be a better fit for OEM tires. I am, however, using slightly larger aspect ratio tires. 285/45/21 and 325/ 40/21. It took some acrobatics (used a grinder on the upper control arm to shave a few mm off and a heat gun to remold the fender liner) to make the front tires fit.
05-29-2022, 09:52 PM | #6 | |
Rep 901
05-29-2022, 09:57 PM | #7 |
Rep 38
05-29-2022, 10:25 PM | #8 | |
OEM CSL Whore
1255
Rep 1,476
05-29-2022, 10:59 PM | #9 |
Rep 385
You are in so cal. I go to Ben too
daytonaviolet1254.50 r33_RGSport13122.00 |
05-31-2022, 10:32 AM | #10 |
Rep 94
Looks great. I’m sitting at a shop as I type waiting to get 15/15 spacers on. I’m getting some wider tires on the OEM rear wheels later this week so I hope the 15mm spacer plus wider tire doesn’t poke beyond the fender flares.
Edited to add: I guess the spacers come with multiple lengths of bolts as the spacerless boxes still feel heavy after the install. With the 15mm spacers out back and stock suspension, the OEM wheel/ tire set up is flush with the fenders. I may have to lose the rear spacers to put on 325/30/21 Pilot Sport Cup 2’s as they run as wide as 355/25/21 MPS4’s apparently. Anybody got a pair of 5mm spacers made for the 2018 gen X6M/ X5M to trade for a pair of 15mm spacers? Edited to add: the tires came in. Think these pilot sport cup 2’s might poke just a bit with the 15mm spacers. upload pic Last edited by OhThatGuyJax; 06-01-2022 at 01:54 PM.. |
05-31-2022, 04:10 PM | #11 |
OEM CSL Whore
1255
Rep 1,476
blackoutF15350.50 |
05-31-2022, 08:12 PM | #12 | |
Rep 901
06-01-2022, 06:57 AM | #13 | |
Rep 94
upload image |
musa424.00 daytonaviolet1254.50 |
06-01-2022, 09:37 AM | #14 |
Rep 27
daytonaviolet did you end up needing the kmac camber kit or have to change bump stops on all four corners to run the V3s that low?
- Jeremy | Instagram: Oahu.Homes
2008 Porsche 997 Turbo Cabriolet 6MT - AWE 750r ...Flame Thrower 2016 Audi RS7 2015 BMW X5M Last edited by ThewhippetsS5; 06-01-2022 at 09:45 AM.. |
06-01-2022, 10:33 AM | #15 |
OEM CSL Whore
1255
Rep 1,476
06-01-2022, 10:54 AM | #16 | |
Rep 94
06-01-2022, 12:35 PM | #17 |
Rep 27
I have yet to lower the car but wanted to get the adjustable camber plates if needed. Your alignment and everything is in spec at 29.5? It looks great
2008 Porsche 997 Turbo Cabriolet 6MT - AWE 750r ...Flame Thrower 2016 Audi RS7 2015 BMW X5M |
06-01-2022, 01:29 PM | #18 | |
OEM CSL Whore
1255
Rep 1,476
KMAC Front Adjustable Bushings (193816-5J) and the SPC Rear Adjustable Upper Control Arms (72115) |
ThewhippetsS55.00 |
06-01-2022, 01:37 PM | #19 | |
Rep 27
06-01-2022, 02:47 PM | #20 |
Rep 38
