06-07-2022, 02:07 PM | #3 |
Occasionally frequent poster
3012
Rep 2,746
And you need an oil change.
I think bank 1 is left, but there's about a 50% chance that I'm wrong. Left, as in driver's side (for USA).
Current inventory:
F22 & G05 Cadillac CT5-V Blackwing w/3 pedals Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2) |
abnatelee581.50 |
06-13-2022, 02:08 PM | #5 |
BMW Enthusiast
582
Rep 46
Bimmer_papi0.00 |
06-13-2022, 02:10 PM | #6 |
BMW Enthusiast
582
Rep 46
Just did the oil change 4-5 days ago and I just wanted your advice if o2 sensor replacement should be done by a mechanic or can it be done yourself easily?
06-13-2022, 08:51 PM | #7 |
Rep 2,926
That totally depends on you and what skill set you have and tools you have. I'd consider it a relatively easy DIY job, but others might not.
06-14-2022, 07:30 AM | #8 | |
3012
Rep 2,746
Also, depending on how much salt and miles the sensor has had to put with, it might be a struggle to remove it. Really, considering how easy it is to do, a shop shouldn't charge you more than an hour's labor to do it, so it comes down to how much you enjoy crawling under your car and doing crap like this. Last thought - don't these cars have two sensors per side? A pre-cat and a post-cat? Hopefully the code tells you which one to do.
Current inventory:
