12-13-2008, 11:22 AM | #1 |
Commander-In-Chief
2194
Rep 8,944
Drives: 2023 M2 Coupe, 2020 GLE 450
SST brake lines
Stoptech now has stainless lines available for our cars. These are good because they are plastic covered to reduce the risk of fraying from rubbing. Picked them up from Zeckhausen ($55 front, $54 rear). I'll probably remove the CDV when I do the lines.
http://zeckhausen.com/BMW/E92_M3.htm
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
12-13-2008, 11:48 AM | #2 | |
Rep 961
That said, the front brake hoses are long, so there's more opportunity for them to flex and soften the brake pedal. The rears are short, so changing them might not be so noticeable. The other change I made at that time was to Castrol SRF. I'd been using Motul RBF 600 in other cars but I've been happy with the Castrol. I thought there was consensus that the M3 didn't actually have a CDV? By the way, did both kits come with flat washers for the hard line bracket? Mine were early production and didn't have the washers, but I had four from another car that I used. I can see them in the photo for the rears, but not the front. |
12-13-2008, 01:47 PM | #5 |
Commander-In-Chief
2194
Rep 8,944
CDV
Maybe I'm not keeping up--point me to the evidence, please.
12-15-2008, 10:40 PM | #8 |
Bored at work....
891
Rep 5,393
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
12-15-2008, 10:55 PM | #9 | |
Rep 5,124
@greg, check out this thread: http://www.m3post.com/forums/showthread.php?t=153462 |
12-15-2008, 11:00 PM | #10 |
Rep 5,124
@greg again, check out this one. Even more definitive:
http://www.m3post.com/forums/showpos...8&postcount=10 |
12-15-2008, 11:02 PM | #11 |
Rep 396
12-16-2008, 12:28 AM | #12 | |
Rep 961
Now, about those washers... Did you get them or not? Thanks! JJ |
12-16-2008, 07:31 AM | #13 |
Rep 3,523
12-17-2008, 01:34 AM | #15 |
Rep 1,432
I got the GruppeM brake lines and I can tell you it makes a difference. Especially on the initial biting when you hit the brakes!
2018 F80 LCI II ZCP ///M3 Mineral White M-DCT| Sakhir Orange Interior| |M Performance Exhaust| |
12-17-2008, 12:39 PM | #17 |
Commander-In-Chief
2194
Rep 8,944
Brake line DIY
I will if I do it myself. I may have my dealer do it if I have the car in for another reason.
12-29-2008, 12:21 AM | #19 | |
Rep 3,303
I know, I know, I'm sure its not that difficult, but I like the peace of mind knowing that a pro did it Cheers, e46e92
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. Last edited by e46e92love; 01-15-2009 at 05:48 AM.. |
01-14-2009, 11:21 AM | #20 | |
Rep 306
I assume you know the car (as many others) brings the pads right to the rotor when there's acceleration followed by sudden throttle liftoff. So in that scenario they would always bite, and with new lines even harder. I've never had problems when following on the track, but in the city when going at city speeds and someone cuts me off it feels like there's more pedal travel to get the same braking power compared to other times. This I assume is the exact symptom that people get the lines for.
01-14-2009, 11:55 AM | #21 | |
Rep 1,432
Like i said, its subjective and I have it in my car for almost 3 months now and must say its a relatively effective mod. Make sure you use good brake fluids like Castrol SRF and bleed out the old one completely. That as a package makes quite a difference. Hope this helps!
01-14-2009, 11:00 PM | #22 |
Rep 961
The M3 doesn't do that, nor does it have the brake drying function. It has DSC and ABS but does not have pre-braking or wet-braking assistant technology.
