06-18-2022, 11:45 PM | #1 |
Qrowna
Rep 12
White Smoke?!
Anyone else been having intermittent white smoke issues? It doesn't happen at start up but only if I've been idling for a while or when I come to a stop light.
I've seen some others with the s63tu that have a similar issue. Im running VRSF downpipes with an RK Autowerks Tune. I've been hearing everything from "its normal when youre running downpipes," to the turbo seals giving out and so on. I have no leaks, skips, or lag. Full 700HP 8mpg everytime and I love it. Please let me know if you've had a similar experience. Thank you all |
06-19-2022, 12:11 PM | #2 |
Fueled by Recycled Dinosaurs!
644
Rep 1,179
Drives: F06 M6
Could be moisture/condensation in the exhaust pipes. It takes a while for exhaust pipe temps build to start boiling it off. Only other explanation I could think of would be coolant. If it is coolant then you likely have a crack or gasket issue. Keep an eye on coolant levels as the only other way to know is engine inspection.
2015 F06 M6 Silverstone Metallic II, Individual Full Leather, B&O, Night Vis, CCB, RKAutowerks (CP Rods/Pistons, DI Cams, CF Intakes, Coated DP's & Billet Diff Brace), InfinityAuto Turbo Inlets, Mishi Oil Cooler, JB4, XHP S3, BM S3
06-19-2022, 08:41 PM | #3 |
Rep 200
Weird I get a big cloud of white/grey smoke when I full send on the highway and it disappears after about a second, so basically only when I'm launching hard from a standstill and it doesn't come back when I'm pushing hard at higher speeds... is it an issue? or normal haha
Current : 2018/2019 M6 Gran Coupe (Last model year)
Current : 2020 E63s AMG (hers) Past : 2018 650i Gran Coupe (Sold) Past : 2016 428i Gran Coupe (Sold) |
06-19-2022, 10:19 PM | #4 |
Rep 7,586
Is it steam or is it smoke? Can you check next time it occurs if you’re not sure which it is? If you can’t tell the difference…then try a google search…this topic has probably cropped up a lot over the decades since many new owners freak out the first winter of ownership. They see white stuff coming out of their mufflers and their first thought is that it is smoke…when it actually is steam.
Know the difference and it may help answer the question or send you on the path to correct the issue.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
06-20-2022, 09:22 AM | #5 | |
644
Rep 1,179
Drives: F06 M6
06-20-2022, 07:00 PM | #6 |
Rep 754
Drives: '13 F13 M6, '94 JDM Supra
On my 13 with 44k mi full dealer service history, I luckily don't have any smoke even under full throttle pulls, and only consumes oil at around 2k mi per quart, all stock powertrain wise.
06-20-2022, 09:41 PM | #7 | |
644
Rep 1,179
Drives: F06 M6
I am thinking about forged rods and pistons though. I read that the F90 pistons are a direct replacement but not entirely sure if I'll use them.
JDMSteven479.00 |
