06-30-2022, 08:30 PM | #1 |
Rep 201
Drives: BMW Z4C 3.0si 3 pedal
Z4 E86 - E46 clutch pedal compatibility
Asking the collective to make sure my findings are in fact correct.
Wanting to swap out the clutch pedal for a non stock pedal that fits the E46 from Garagistic. Brand new item from them made from Billet Aluminum and comes with bronze bushings. https://www.garagistic.com/products/...c7b6d9e8&_ss=r From what I can determine the two clutch pedals are the same. I know that others have swapped in the Mason clutch pedal which fits both the E46 and E86. TIA |
06-30-2022, 11:38 PM | #2 |
Rep 1,088
Drives: Lots of BMWs
Garage List 2018 M4 Vert [0.00]
2006 Z4M Roadster [0.00] 1995 540i [0.00] 2008 BMW M5 [0.00] 2019 i3 Rex [0.00] 2021 X7 40i MSport [0.00] |
According to realoem there is no other car that shares the clutch pedal assembly. Perhaps cause of the smaller interior its smaller than E46.
https://www.realoem.com/bmw/enUS/par...&q=35306760107 The E46 pedal is specific to it only also. https://www.realoem.com/bmw/enUS/par...&q=35311163870
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX 2021 X7 40i MSport, 2006 Z4M 6spd |
07-01-2022, 06:25 AM | #3 |
Rep 2,707
Drives: Built not Bought 04 Z4 VF. E70
I have the mason pedal that is designed for the E46. Fits my E85 perfectly. No install issues at all. Removal of the seat was a necessity for me to squash down in the footwell.
Disclaimer: always unhook battery before working on any electrical disconnect.
W2A Intercooled Vortech V3Si, custom ducting, Alpha N, 60# Bosch,2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial, magnaflow,SS race muffler, 42 design,3.91LSD, H&R, Hotchkis,ST coils,Konis, Megan camber arms, AKG SS, Nylon mounts, Poly bushings, Carbon interior, CF Aero.APEX
07-01-2022, 01:17 PM | #4 |
Rep 201
Appreciate the input, did some further checking. Called Mason Eng and the E46 and E86 are identical clutch pedals.
So the new Garagistic Billet pedal will be a direct fit. It's on the site with a 30% discount as pre-order 195.00 . After the launch it goes to $295.00 I believe. |
