07-23-2022, 01:13 PM | #1 |
Rep 80
Lap Belt Harness Mounting
How do you guys do the lapbelt harness mounting?
Since the stock seat belt mounts to the seat base. With a VAC floor mount, it seems the only way is to use an eye bolt (m8 x 1.25) which is not a common size for seat belt mounting eye bolts. |
11-20-2022, 08:47 AM | #3 |
Rep 1,415
Not sure if this helps but here is my VAC setup. To get everything to fit and avoid clearance issues this was the only config I could get to work after speaking to VAC on two occasions. It's finally set up well.
The lap belt adapter/mounting bracket had to be mounted under the floor mount to avoid clearance issues with the bolt/nut hitting the bottom of the seat when sliding back and forth. Last edited by MaX PL; 11-20-2022 at 08:54 AM.. |
11-22-2022, 12:58 PM | #4 |
///M Powered for Life
11517
Rep 10,345
I use BK mounts on OEM sliders and they have a specific place to insert the lap belts
11-24-2022, 02:43 AM | #5 | |
Rep 80
Does both your harness end and stock seat belt end pivot on that bolt? How did you get it to pivot freely using the vac mounting hole. |
11-26-2022, 08:27 PM | #6 | |
Rep 80
11-26-2022, 09:43 PM | #7 | ||
Rep 1,415
The harness end can likely pivot but I have everything tightened down firmly as I don't need it to. Quote:
I found thats its not at all necessary and the seat is completely level. If you want to use spacers you'd need them in the three other places whether you mount the adapter under the floor bracket or above. Just use some large washers if you absolutely want to do this. |
