09-20-2022, 09:32 PM | #1 |
Rep 319
M3 seats
Does anyone have a solution to help w the seats on track days? I found that it seems the seats in my CS were a real limiting factor in my last track day, I felt I was sliding all over the place. Was curious if anyone else has that issue or even better a solution without going full race buckets?
I felt the car had more than I was able to get out of it, I’m not fast but felt I had more in the car if I wasn’t sliding around, for reference I was running about 2:45 to 2:50’s at Monticello recently. But felt I could have been more consistent in the low 2:40’s if I was more confident and held in place |
09-20-2022, 09:40 PM | #2 | |
///M Powered for Life
11517
Rep 10,345
A forum member here runs that setup. Still ok for a daily driver and a huge step up for track driving. My CS had less than 700 miles on it when we did seats and the bk harness bar. You can't progress when you're holding on for dear life |
Montaver2276.50 |
09-20-2022, 09:45 PM | #3 |
Rep 319
I’m not sure if it’s the seat design, i think it’s more that’s its full leather I think of there were alcantara centers or something it might work, can’t argue that full buckets would work but my CS is my family car I usually track my 997
Do the scroth quick fit pros work w the stock seats? I know it would be ideal at all but was thinking it might be a decent compromise for 2-3 track days in the CS a year next season |
09-20-2022, 10:19 PM | #4 |
Rep 837
Before you buy anything-
1. move your seat back a couple inches. 2. give the belt a quick jerk to lock it. 3. slide the seat forward to compress yourself in the belts at your normal driving position That can go a long ways to keeping you in place with stock hardware. |
pilotedecourse52.50 F80RN900.00 papasmurf_m3454.50 SYT_Shadow11517.00 sly1types431.50 The_Werm214.00 phefner374.00 5thscaleracer70.00 |
09-20-2022, 11:04 PM | #5 | |
Rep 36
If the seat material bothers you but you want to stay close to OEM, you can look for a pair of the BMW OEM seats with the cloth finish to swap out. With the cloth and the seatbelt trick that theruleslawyer references above, I don't find that I slide around an unacceptable amount at the track. |
09-20-2022, 11:33 PM | #6 | |
Rep 837
https://www.summitracing.com/parts/g...aSkaAlyp8P8HAQ Its really an autocross thing, but it seems like it would just break open in any real collision allowing the seat belt to do its thing. |
09-21-2022, 12:01 AM | #7 | |
Rep 295
So I will still be driving the F80 to the track but it is mostly dedicated for track driving now. I'm also in the market for seats, harness bar / half cage / etc. Overall the setup I'm imagining is an RSR bolt in half cage, halo seat, 6 point harness. But I think I can be talked into other options. Some questions- 1. Thoughts on running a halo seat while driving to and from the track? I realize the visibility is a little less, but seems manageable. 2. Do you recommend just leaving all airbags be? Or do you do anything with them when running seat+harness bar (disabling them when on track for example). 3. So I'll be using my 3 point harness when driving to the track, right? Will I be able to have the 3 point installed at the same time as the 6 point? Or maybe that is why you suggest the scroth quick fits, because that would be impractical to try to deal with 6 points while driving to the track? |
09-21-2022, 08:34 AM | #8 | ||
11517
Rep 10,345
The ones they use is a mini cooper harness that is designed for the type of seat the F8X has. Note I still don't recommend it, but people are running this. If you have an instructor it won't fly, but without an instructor I can imagine someone can get away with it Also, don't group 'buckets' into a single group as if they are all the same. 'Bucket seats' range from seats that could be stock in an M3 like the Pole Positions to containment seats you see in IMSA. That is a massively wide range. It is perfectly doable to install a moderate bucket seat like the Cobra Nogaro on your DD and then run a 4 point Scroth belt setup which is officially accepted, and which can be removed in 30 seconds. |
sly1types431.50 |
09-21-2022, 08:42 AM | #9 | |
11517
Rep 10,345
Originally we bought the Sparco Ergo with removable halos, then after a few years we noticed we were not removing them anymore and swapped to the OMP HRT-400 with built in halos. I struggle to see a disadvantage to airbags other than their weight. I am definitely not disabling them. If you choose the right setup -BK, full stop- then you'll retain 3 point and 6 point functionality. 6 points cannot be used on the street, or without a neck restraint for that matter. It has little to do with practicality and much to do with having your head separated from your body in an accident. I took a photo of the padding in the roll bar/harness bar in the GTS for you to get an idea of what you should replicate if you are going in this direction |
09-21-2022, 09:40 AM | #10 |
Rep 115
Here is the answer. Unfortunately, I don't see it for sale anymore. Might be able to search around for one somewhere and find one second hand.
https://store.racerdirect.net/cg-loc...-seatbelt.html I was lucky enough to have a friend give me one, who went to a full harness. It has been life-changing for the stock seats. I don't even think about needing buckets/harness anymore, although I know it would certainly be better. It gets me 70% of the way there. |
pilotedecourse52.50 |
09-21-2022, 09:42 AM | #11 | ||
Rep 295
Seems like you need to code out seatbelt chime if wearing the 6 point? |
09-21-2022, 10:24 AM | #12 |
11517
Rep 10,345
melanthius255.00 |
09-21-2022, 11:28 AM | #13 |
Rep 109
A proper race seat makes all the difference on the track. I dropped over a second in lap time just from replacing the stock seat with a race seat and 4-point harness. I could finally feel how the chassis was working and was able to drive harder through the corners but still in control. I could actually relax in the corners rather than gripping the wheel for dear life.
I installed a OMP HTE-R XL. For tracking purposes probably the single best modification I made to my car. |
09-21-2022, 08:58 PM | #14 | |
Rep 928
The tensioner hack is a great but this setup holds me a little better and the minimal seat cushioning allows my butt to talk to the car with less interference. |
09-22-2022, 09:12 AM | #15 | |
11517
Rep 10,345
Legal for all organizations, comfortable enough for significant others, looks great, huge difference in body control and safety by allowing a neck restraint |
D_SheerDrivingPleasure1106.00 sly1types431.50 |
09-23-2022, 12:14 AM | #16 | |
Rep 625
sly1types431.50 |
09-23-2022, 06:12 AM | #17 | |
Rep 928
Fun. I'm using Bray Krause side mounts + OEM manual sliders which I harvested from the seats of an old 3 series that was at a local junk yard....Some forum members reported slop when using aftermarket sliders. The airbags need to be coded. Mine were done remotely. |
09-23-2022, 01:22 PM | #18 | |
Rep 940
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
09-23-2022, 03:34 PM | #19 | |
Rep 928
Some people have reused the electric motors with the Cobra seats to maintain fore/aft control. That's clever but for track use I prefer the speed of the manual slider. I'm in/out of the seat a hundred times on a track day and a motorized control would be too slow to keep up. I do miss the seat heaters but I think you can rig something up. I'll share some more pictures next time I with the car. Might not be until next week. |
sly1types431.50 |
09-29-2022, 01:59 PM | #20 | |
Rep 295
K. I'm sold on the BK harness bar. Is it correct that both the harness bar, AND the racing seats are all supposed to use factory rails? |
09-29-2022, 02:27 PM | #21 | |
11517
Rep 10,345
The oem rails and bk seat mount setup also connects straight to the car, so no modifications needed there either |
09-29-2022, 07:24 PM | #22 |
Rep 469
