09-30-2022, 02:21 PM | #1 |
Rep 7
Question about troubleshooting error codes
Hi,
I'm very new to BMW (this is my first), so I'm trying to find the right approach to troubleshoot error codes and eventually finish this project (I'm rebuilding an F86 after front-end collision). I've replaced all of the known broken parts, cleared all errors (with Bimmerlink), etc. I've done a bit of this with Audi in the past, and a lot of times when there where lots of codes being thrown, it would make sense to start on a specific code and sometimes that would clear up a bunch of the others. Not sure if BMWs behave the same way when it comes to error codes. Anyway, here is the current list of codes that I'm getting. Any ideas on which ones would be the smartest to start looking at, and which ones to wait on? Code:
0D HKFM 1 error 80177C: HKL: Blockage of the tailgate detected 12 Motor electronics 1 error 1D2404: Map thermostat, control: line break 29 Dynamic stability control MK60 E5 1 error D355AA: Signal error (status ARS, ID: ST_ARS) - Invalid 2C Parking maneuvering assistant 1 error 803201: Power supply Front ultrasonic sensors: short circuit between positive and negative 39 Vertical dynamics management 2 errors 480C01: Oil level too low or no signal (engine running, vehicle stopped) 480C02: Oil level too low or no signal (vehicle is running) 78 Automatic heating and air conditioning 1 error 80119D: Motor stratification front left: blocking Oh, and I replaced the battery, but haven't coded a new battery yet. Could that make a difference? Thanks for any help! |
09-30-2022, 04:29 PM | #2 |
Rep 592
Drives: 2018 X5M , 14%E2%80%99640i ver
I'm no geek ( have not even plugged my Carly or bimmerthingy, but first place is register battery.
Slickrick2211.00 |
10-20-2022, 07:46 AM | #4 |
Rep 340
Drives: Several
Garage List 2004 Ferrari 360 Sp ... [0.00]
2015 Ford F150 Lari ... [0.00] 2015 Porsche GT3 [0.00] 2017 BMW X5M [0.00] 2020 BMW X7 M50i [0.00] |
Are these codes throwing up any CELs or dash errors? Or just codes when you run the diagnostic software? I’m wondering if any of the parts need to be “programmed” to the car?
2023 GMC Denali Ultimate
2021 Porsche Cayenne GTS 2019 Ford Raptor SuperCrew 2015 Porsche GT3 2004 Ferrari 360 Spider 6M |
11-01-2022, 10:44 AM | #5 |
Rep 7
Thanks for the responses. Here is an update in case it helps anyone searching later.
12 Motor electronics 1 error 1D2404: Map thermostat, control: line break - This appears to actually be a bad thermostat. Looking to replace this weekend. Ordered a stock thermostat, but now wondering if I should have gone with 90 degree "upgrade"? 29 Dynamic stability control MK60 E5 1 error D355AA: Signal error (status ARS, ID: ST_ARS) - Invalid - Related to the "Oil level too low" errors below. (And cleared up when 480C01/480C02 was resolved) 2C Parking maneuvering assistant 1 error 803201: Power supply Front ultrasonic sensors: short circuit between positive and negative - I had replaced 2 PDC sensors with very similar, but ultimately incompatible sensors (Mercedes part number, stupid move on my part). Replaced with the correct sensors and this cleared up. 39 Vertical dynamics management 2 errors 480C01: Oil level too low or no signal (engine running, vehicle stopped) 480C02: Oil level too low or no signal (vehicle is running) - This one was misleading for me, as I somehow thought it meant "engine oil", which I knew was not low. It of course means "power steering fluid", which also feeds the active sway bar on these cars, and other vehicle dynamics systems. And just as it was trying to tell me, mine was low. Pretty embarrassing. The good news is both this error and D355AA go away with the correct amount of power steering fluid. Last edited by thowell; 11-03-2022 at 10:10 AM.. |
Chilled370.50 Slickrick2211.00 |
