10-01-2022, 12:33 AM | #1 |
Rep 129
Steering return to centre feel after alignment
Hey guys,
Just got my car wheel aligned and noticed the steering is very light and has less of a return to centre feel. Caster is up at 8.5 degrees each side which shouldn't feel like this from memory. The rest of the wheel alignment specs are good too. Could there be a problem anything worth checking? EDIT: only happens on left turns (RHD car).
2011 E92 M3 - Mineral White - Pure Edition I
10-02-2022, 04:40 PM | #2 |
Field Marshal
6735
Rep 1,829
Drives: '08 E92 M3
Please post a picture of the before and after final alignment spec sheet.
1) Were the tire pressures increased? 2) Did the front camber specs change to become more positive? 3) Seek to maximize caster. Increasing tire pressure reduces pneumatic trail which is worse for residual alignment torque (feel). But increasing caster increases pneumatic trail which increases aligning torque. Increasing camber increases camber thrust force and increases aligning torque.
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
///M Power-Belgium64693.50 Lozza4739.00 |
10-02-2022, 11:34 PM | #3 | |
Rep 129
My caster is maxed out (same settings pre alignment) however I went from -1.6F camber to -3.0, for a track day. Tyre pressure remains the same.
10-14-2022, 03:28 PM | #4 |
Rep 24
I noticed the same thing after alignment - more camber and caster. I asked a few people about this and it is apparently normal (especially if you are running spherical thrust arms).
10-14-2022, 07:27 PM | #5 |
Rep 334
past a certain point (beyond -3.0 in my experience) more camber will give you less on center feel when driving straight, but it grips up amazing in the corners
