EXXEL Distributions
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      10-02-2022, 08:08 PM   #1
Jlaflo
Drives: BMW M3 F80
Rollinguyf80 street/track build
Hi guys, starting this thread to capture my journey on a new build. There was a F80 in the spec I wanted for sale locally so I jumped on it. My previous build was a street / track s2000. I have the same goals for this new build
If you want to follow the build on IG @Rollinguyf80
Here's pictures of my new 2016 F80
And my previous s2000 build
thekidd36.00
NYG11054.50
David0ff1060.50
phefner374.00
ck_M364.00
      10-12-2022, 10:12 AM   #2
NYG
NYG's Avatar
Drives: Audi R8
That's a purty S2000 man.
Good luck, will follow.
      10-13-2022, 02:55 PM   #3
///Mobbin
///Mobbin's Avatar
1478
Drives: m3
Second that, sweet S2k, and congrats on the new car!
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
      10-15-2022, 02:20 PM   #4
Jlaflo
Drives: BMW M3 F80
As of 10/11/2022 i installed
-VRSF charge pipes
-Crank bolt capture VTT
-Red line diff fluid, OEM manual fluid, and Castrol 0w40 engine oil
-CONVERSION STUD 14×1.25-14×1.5* 78mm Black Bullet Nose Stud Kit
-PFC 11 brake pads
-Titan 7 18x10.5 +25, Falken rt660 275/35/18 square
-Did a mhd staged 1 tune to see what all the hype is about but may take it off for the track lol, way too much torque and I want to learn the car properly.
-Eibach pro lowering springs, Ground control camber plates.
During all of this found out I have a massive valve cover leak near the passenger side which sucks was hoping not to have any crazy maintenance to do but here's the first one I noticed.
Have an alignment set up for this upcoming Monday. Shooting for a more track orientated alignment for a squared set up. Any tips would greatly be appreciated!
      10-15-2022, 03:30 PM   #5
polarbearz
polarbearz's Avatar
Drives: BMW M3
-VRSF charge pipes
-PFC 11 brake pads
Attachment 3008764
Attachment 3008765
Attachment 3008766
Do you think you will be able to run 295/30/18 or even wider tire with 30 profile on et25 in the rear? It seems pretty tight
      10-15-2022, 06:01 PM   #6
Jlaflo
Drives: BMW M3 F80
I think so, With a little camber. No clue what my camber is right now. But I’m sure I have a little more room because I’m not that low.
Not sure what’s the go too range for negative camber in the rear if your tracking tho.
      10-15-2022, 06:09 PM   #7
polarbearz
polarbearz's Avatar
Drives: BMW M3
I have -2.2 now in the resr
      10-17-2022, 11:54 PM   #8
uncle ben
uncle ben's Avatar
Drives: 06 330i
Love the white on white look.
      10-18-2022, 11:10 AM   #9
Jlaflo
Drives: BMW M3 F80
100% I can run 295/30/18 or 35 on the rear.
      10-18-2022, 11:13 AM   #10
Jlaflo
Drives: BMW M3 F80
Thank you!
      10-18-2022, 02:20 PM   #11
heyyouduh
Drives: 2018 M3
what happened to the s2k? they're pretty different cars, let us know your thoughts on the two platforms when you get a chance to track the M3!
      10-18-2022, 04:41 PM   #12
phefner
phefner's Avatar
Drives: F30 340, F80 M3
Gorgeous.
What's your expectation on # of track days in a season? We just finished our last track day of the season here, so it's time to start working on what mods to install this winter.
Great thread.
Quietly Effective
      10-18-2022, 07:21 PM   #13
Jlaflo
Drives: BMW M3 F80
Originally Posted by phefner View Post
Gorgeous.
Great thread.
I'm down in Miami so our season starts now lol.
Probably 1 track day every month more or less. Already signed up for a night event at Sebring Dec 10th. Just making sure the car is ready before then.
      10-18-2022, 07:23 PM   #14
Jlaflo
Drives: BMW M3 F80
That's the big question. I love my S2k, It doesn't have much power but the car is faster then most cars with double + power then me, and a very exhilarating car to drive. If I don't fall in love with this chassis within 3-4 events, I'm going to stop modding it.
      10-18-2022, 08:07 PM   #15
D_SheerDrivingPleasure
D_SheerDrivingPleasure's Avatar
Drives: F80
In case you can't tell, the entire forum is drooling over your S2K!
Pm when you're ready to sell it. 😀
NYG11054.50
      10-19-2022, 09:20 AM   #16
NYG
NYG's Avatar
Drives: Audi R8
You will. The S2K is an incredible track car especially when it comes to weight but the F8x chassis is outrageous and miles ahead in terms of stiffness.
      10-19-2022, 02:55 PM   #17
shaddy
shaddy's Avatar
Drives: M3
Great taste man, love the white-on-white look! At some point, I wanted to pick up some white TEs but now see Titan7 offers those in white for the F80, I think before it was only for their JDM applications. Looks good. I run the same specs and you can fit a 295/30 square, there are quite a few running aggressive offset and a wide tire. I'm on 275/35 and have tons of room, even threw a spacer F/R. I will probably go to 285/35 or 295/30 next. Most F8x guys are very conservative on fitment
I came from a lighter roadster also, I had an ND before. I miss the lightweight steering feel and slow car fast type of fun. The F80 is a different beast, heavier but albeit more capable and a different tier of car. In the same way your S2000 can compete with cars with double the power, the F80 is enough car to compete with anything out there. Look forward to your impressions! What you will probably find is the F80 is pretty easy to drive IMO, with the right setup it communicates well.
Not sure if MHD does it cause I'm on BM3, but see if there's a boost-by-gear option to remove that power spike. Makes the car way easier to drive. Also if you find the steering feel lacking, look into getting the GTS steering coded in, was a huge improvement for me! Enjoy!!
IG - shaddyy
      10-19-2022, 09:03 PM   #18
Jlaflo
Drives: BMW M3 F80
MHD does have boost by gear. What would you recommend to put it as?
      10-19-2022, 09:12 PM   #19
Jlaflo
Drives: BMW M3 F80
And I wanted to run 295/35 but I couldn’t find much Information on this to make it work. Now I know it will work with a little massaging. My s2k is running the most aggressive setup I could run. I did noticed most bmw guys are conservative with their wheel specs lol or maybe the guys running really aggressive setups don’t post much
      10-20-2022, 12:39 AM   #20
shaddy
shaddy's Avatar
Drives: M3
When I was Stage 1 BM3 I started at 10%, when I moved to Stage 2 I upped it to 20%. Main idea is to flatten the torque curve but maintain the peak HP. I only did boost reduction in gears 1-3. My local tracks I'm primarily in 3rd due to longer gearing with the MT. I shift to 4th on the longer straights and want to maintain the higher power to keep pulling into the braking zone. Ended up being a setup I enjoy on the street too as it makes me smoother around town.
Yeah I think the main issue is the tire height/avoiding the spring perch. What I've seen is to avoid tires taller than 26.3" (295/35/18 is 26.1) to avoid scraping the liners too much, and ideally run a shorter spring/no helper to get the perch avoid the tire. But with the 295/35 the tire is pretty damn tall, so most people do a 295/30 instead. That being said if you run a spacer and get the effective offset around +15, dial in the camber between -3.5/4, I think you would be good. This is all theoretical though based on what I've seen a lot of people run.
The Assist M4 runs an 18x11 square with 295/35. They do have front lower control arms to play with track width, but we should have extra room with 18x10.5 instead. The rear will be tight but camber and/or pull the fender a tad for some extra clearance and boom. I will try to explore this more when my 275s wear and if I can find some setups locally to play with before I commit!
Also aside from the Assist M4, I also love the sunbeam F80. They run 18x10.5 RIA and a 295/35 A052 up front. Clearance looks good:
IG - shaddyy
      10-20-2022, 12:57 AM   #21
henrylee
henrylee's Avatar
Drives: 2018 F80 M3 6MT
I miss my s2000
2018 F80 M3 6MT///Black Sapphire w/ Sakhir Orange Leather
2006 S2000 AP2 Laguna Blue Pearl 6MT
      10-20-2022, 05:18 AM   #22
polarbearz
polarbearz's Avatar
Drives: BMW M3
-VRSF charge pipes
-PFC 11 brake pads
Attachment 3008764
Attachment 3008765
Attachment 3008766
I am also on eibach lowering springs. How's the room in the front? Do you think 295/30/18 will fit in the front with -2.6 camber? I think Eibach springs are kind of thick in the front.
f80post
