10-27-2022, 06:44 PM | #1 |
Rep 74
issues coding after installing carplay unit
has anyone else had troubles using bimmercode after installing an aftermarket carplay unit?
i have one that attaches to the HU and now when i try to connect it goes to 12% and fails. Just seeing if anyone else is having this issue its a 2015 X5 35i with a wireless carplay unit |
10-28-2022, 12:43 PM | #2 |
Rep 36
You'll have to update the firmware/MCU of the MMI. Downloads for pretty much every model can be found in this thread. Make sure you pick the right model because they're not interchangeable. If you don't know which one to download, I would email the manufacturer and ask.
11-02-2022, 12:08 PM | #4 | |
Rep 74
https://www.aliexpress.com/item/1005...431bf19cCEyzp1 do you know which one this would be? also is there a way to to scan without the HeadUnit? |
12-01-2022, 01:59 PM | #5 |
Rep 102
I have had JoyeAuto for carplay/Android Auto for over 2.5 years and no problems as i do coding via bimmercode for my youtube channel. Infact i have done multiple HU coding as well.
Are you sure all the wires were plugged in ? and are you using Apple or Android device? is the dongle wifi or bluetooth? some of the older dongle are no longer supporting the Bimmercode app. check the developers' website. |
12-04-2022, 01:49 PM | #6 |
Rep 552
Drives: 2014 X5 35d, 2008 Lexus IS-F
No issues with any type of coding.
You will have issues updating firmware with ISTA-D, so it's best to put all back to stock if you're using it to update. Pretty annoying.. I have the 4x4 Android 10 unit. |
12-07-2022, 09:01 AM | #7 | |
Rep 144
Context: I used a third party vendor to do the ID6 upgrade and code in full-screen Carplay. As a result, I can no longer access the iDrive options via Bimmercode. This isn't that big of a deal, to be honest. More of an annoyance that I'd be interested in a workaround for. |
