11-05-2022, 12:17 PM | #1 |
Rep 327
Code out backup camera warning?
I got the Bimmergeeks ProTool to clear out some seat codes,which worked great.
Does anyone know how to navigate to the backup camera warning? That stupid thing blocks the middle of the camera view, particularly when I have it on wide-angle view.
2021 Individual Grigio Telesto Gray Pearl Metallic X5M C, BC Forged, Dinan tuned, Dinan suspension, MAD Downpipes, Dinan Exhaust. More to come.
Owner, Designer, Tuner- A&A Corvette Superchargers WWW.AACORVETTE.COM |
11-08-2022, 09:44 PM | #3 | |
Rep 327
Anyway, I ordered a different WiFi interface to work with it. I should have it on Thursday. Thanks for the advise.
11-09-2022, 08:28 AM | #4 |
Rep 272
I use Kies Motorsports adapter. It pretty much works with every app and FAST response
https://www.kiesmotorsports.com/prod...a532d3f1&_ss=r |
11-09-2022, 02:54 PM | #5 |
Rep 4,431
I use Bimmercode/link with this obd adapter for my X5M. Works great
https://www.amazon.com/gp/aw/d/B06XG...b_b_asin_title
ModeCarbon V1 CF lip/PF AG CF SS ext./ARKYM CF Diffuser/OSS AE's/B&G Springs/CF Performance Spoiler/V2 Led Performance SW/Meisterschaft GT exhaust
11-11-2022, 05:37 AM | #6 | |
Rep 327
Both Bimmercode and ProTool will clear it only in the normal view. Just in case anyone wants to know, I went through a lot of stuff and both seem to be able to do the same things as far as coding goes. I will say that the ProTool is WAY faster though. ProTool also has pretty decent diagnostic functions. I don't know if Bimmercode does or not. It is quite a bit more expensive than Bimmercode.
11-11-2022, 03:36 PM | #7 |
Rep 7,584
Bimmercode is for coding and its sister app BimmerLink is for diagnostics.
If you still get camera warnings and you've successfully coded that feature to be NOT ACTIVE...can it be you only coded one of the camera parameters off? Or maybe the HU_NBT setup is different than the HU_NBT_EVO setup. I just have the NBT_HU and I don't get any camera warning in regular or wide angle view. You can see screen shots from the Bimmercode website for coding camera and startup warnings off (as well as night vision warning if you have that option)…and you can see the regular rearview and wide angle rearview in pics below. Regular rearview uses the guide lines…wide angle view does not.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 11-11-2022 at 04:16 PM.. |
