BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
BPM
      01-02-2009, 02:16 AM   #1
1001
Drives: 06' 325i/08' 350z/09' 128i
Clutches for auto m3
hi everyone, i'm in the market to get a m3 but just wondering how often does the clutch needs to be changed for an auto m3 because i have heard that the clutch cost 3000 to change. i'm also considering a c63 but that goes in the shop every 10k miles so just doing some research now. thanks for the help.
      01-02-2009, 02:27 AM   #2
M2381
M2381's Avatar
Drives: E92 M3, GTI
BMW says the clutch in the DCT is suppose to last a lifetime, exactly how accurate is that statement though?
      01-02-2009, 12:18 PM   #3
jml
jml's Avatar
128
Drives: X5M, GT3RS, GT4
Service adviser told me it's not a classified as a wear item, so it's covered under warranty.
      01-02-2009, 12:26 PM   #4
1001
when the warranty is over then its like 3000 i guess. For example if the clutch needs to be change every 30k miles, then that means only for first clutch is covered under warranty and the next ones are on your own and if i put about 1000 miles a month on the car then i need to pay 3000 to change the clutch every 30 months. i just want to know after how many miles does the clutch needs to changed so i can decide either a m3 or a c63.
      01-03-2009, 01:11 AM   #5
rouxeny
Living the aloha
rouxeny's Avatar
Drives: 2017 LBB M2
DCT transmission at Tischer is almost $9700.
http://www.trademotion.com/partlocat...layCatalogid=0
      01-03-2009, 09:35 AM   #6
jml
jml's Avatar
128
Like I said, it's not a wear item that you should have to change under 100K. They are wet clutches INSIDE the unit and are not serviceable. By the design I can infer that BMW never expects that they will wear out or need servicing. In 5-7 years we may come to find out that under certain conditions they were wrong. Either way, my advice to you is to get an extended warranty if you plan to keep the car outside of 50K. The parts for this car are not cheap and they will break if it's anything like the E46M3.
m3post
