12-09-2022, 08:40 PM | #1 |
Rep 48
Minimum M4 Track Prep for Experienced Driver
I just got a 2020 F82 M4 competition DCT and would like to occasionally track it. I've done a lot of track days during the past decade in Porsches, so I could be classified as an 'advanced' driver.
I'd appreciate suggestions on what track prep I need to do (pads, brake fluid, rotors, tires, etc.). I'd like to do the minimal prep needed to make the car durable on the track, and am not interested in mods to optimize the pace of the car, since I'll only be doing about 8/10ths in this car. Also, my understanding is that the factory warranty isn't voided if the car is tracked - correct? |
12-09-2022, 09:59 PM | #2 |
Rep 452
Drives: 2018 BMW M3 CS (F80)
Honestly - these cars already come great out of the box for track use with little changes required. I have only changed the brake fluid to Castrol SRF and pads to Ferodo DS1.11. It’s great on the track - but I’m sure other experts here provide more insights.
Manifold6.00 |
12-10-2022, 11:41 AM | #3 |
Rep 625
I second what RKP says, brake pads and fluid. But I would also add to that list a nice set of Camber Plates. Vorshlag makes great ones that work with the factory struts and springs. These cars need more front camber, or else you end up blowing the outside shoulder off a new set of tires in a couple track days.
Powerslide1098.50 |
12-10-2022, 04:53 PM | #4 | |
Rep 48
12-10-2022, 09:12 PM | #6 |
Rep 625
-3 degrees +\- a 1/2 depends on individual car setup. But in general the car needs more front camber.
I read someone here on the forum ran the “lap of America” where you drive like 3000miles and hit up a bunch of race tracks and run laps. Apparently they had no issues running track camber on the road. Maybe they will chime in. But if you are concerned, you can mark your camber plates and before you drive on track, set it to -3, then after you are done, set it to a more conservative -2 or whatever. |
Manifold6.00 |
12-11-2022, 12:52 AM | #8 |
Rep 48
Do you guys find that the optimum track camber depends on the tire? Michelin Sport Cup 2 has an asymmetric tread with the outer part being gripper rubber, the rest of it harder rubber for better wear.
12-11-2022, 10:34 AM | #9 |
Dont listen to me
810
Rep 579
+1 for just brake pads, fluid, and camber plates!
I run Performance Friction 11 pads, Motul 660, and Vorshlag camber plates at -3.0 camber with -0.3* total front toe (toe out). Stock tires pair well with the stock suspension. a good set of 200 treadwear tires is a bonus item just for heat management and more consistent lap times but if you are daily driving the car on normal high performance tires (~300tw), then you just have to remember to drive the car at a pace that does not exceed the limit of that tire. For the stock Michelin Pilot super sports or PS4S tires, in a 20 minute session, I get about 4 or 5 fast aggressive laps (middle of the session) before the tires start noticeably falling off and you can see it in the lap times.
Instagram: @thatwhitem4
12-11-2022, 12:28 PM | #10 | |
Rep 48
What 200 tw tires do you guys use with the 20" OEM wheels? I've been running Cup 2 on my GT3 for years, but recently switched to Goodyear Supercar 3, which I like better. |
12-11-2022, 07:21 PM | #11 |
Rep 625
I ran the supercar 3 on the oem 19” wheels. They worked great on the car, but the only issue I had was excess outer shoulder wear on the front tires. I’ve since switched to nitto nt01’s on 18” wheels and they seem to be wearing much better, but they are no faster than the supercar 3’s, which surprised me.
Manifold6.00 |
12-12-2022, 11:38 AM | #12 |
Rep 3,788
You'll need race pads, SRF to compensate for brake heat produced by platform and camber plates so that your tires last more than a day without eating away the shoulder.
That should be the bare minimum. |
///M Power-Belgium64686.00 |
12-12-2022, 12:41 PM | #14 | |
Rep 3,788
///M Power-Belgium64686.00 Manifold6.00 |
12-12-2022, 12:44 PM | #15 | |
Rep 3,788
The mixed sidewall construction of the PS4S is crappy on the track. They're only a pin drop slower than Super Sports but are very finicky/hard to get temperature in/much more sensitive to pressures I tracked the PS4S on my F8X and R8 before - won't ever do it again. |
12-12-2022, 04:07 PM | #16 | |
Rep 36
Motul 600 PFC 08s Girodisc Ti Shims Speed Engineering Front Brake Ducts 18"x10" (can go wider square) w/ 200TW tires (Falken 615k) Vorschlag Camber Plates set to -3.0 degrees (I just leave it there all the time because adjusting is a PITA) Front "mud" flaps (the side of your car will thank you) |
12-13-2022, 11:08 AM | #20 |
Rep 3,788
12-13-2022, 12:48 PM | #21 |
Rep 48
Yikes. I've used many sets of Cup 2 in my 991 GT3, but got 6-10 days out of them. 3 days is crazy, that's $600-700/day just in tires.
12-13-2022, 02:37 PM | #22 | |
Rep 3,788
RS4/NT01 are superior options for this. |
