12-28-2022, 11:08 AM | #1 |
Rep 372
Intermittent starting issues
Good day gents,
My 2010, with 66k miles, has had intermittent starting issues for a month. I highly suspect it may be attributed to my starter crapping out. All lights work fine car just won't start just click. If I wait 15 minutes it will fire up sometimes, or the next day. My battery is four years old, and the last time I checked the in car voltage, it was around 14. I understand there could be other possible starting culprits, such as bad ground, IBS, etc.. I reached out to an indy shop here in NYC to find out the labor on a starter job, and I was told it would be $800 since it's a lot of work getting to the starter. Does this labor sound about right? |
12-28-2022, 12:31 PM | #2 | |
Astronaut
514
Rep 732
The shop quote actually seems fairly cheap because I've helped change a starter and it's not a quick job at all. I had starting issues not long ago where all of my comforts and lights worked but as soon as I pressed start, the whole car seemed like it would reset. The battery was so dead, I couldn't even jump the car with my SQ5. I was hoping it was just a bad ground because I didn't want to do another starter job or even an alternator job. Do yourself a favor and change the battery first. It's the cheapest and quickest option to troubleshoot.
Instagram | @undisclosedm3
"Never think that you are above taking out the trash." |
12-28-2022, 01:31 PM | #3 |
Rep 938
Drives: E90 M3
For what it’s worth, my battery, starter, and alternator all went within a month or two of each other. Possible both starter and battery are weak…it’s always a gamble without a proper diagnosis.
Quote seems in the range, gotta take out a bunch of crap to get to it. Not to hijack the thread, Vuu we picked up a SQ5 earlier in the year and I love that thing. |
12-28-2022, 03:21 PM | #4 | ||
Rep 372
Thanks for the insight. I will revisit the battery, although that distinct click sound aligns with a starter-related issue. I do wish I was more mechanically inclined like some of you guys. I have trust issues whenever my car needs to go in for work. I assume it may be a good idea to change my TAs while the shop has the parts out. One of the banks threw a code a few months ago, and then it disappeared. Quote:
Ok, glad the quote seems inline. |
DrFerry6734.50 |
12-28-2022, 10:42 PM | #5 |
Rep 307
Have the same issue currently. Noticed if I let the car sit for longer than a week it starts fine but if I let it sit for like 24-48 hours it has an issue starting. My mechanic said it’s a bad ground. Bought a new battery anyway just in case.
SpacegrayMe90134.50 |
12-29-2022, 12:02 AM | #6 |
Rep 1,138
Drives: 2009 E92 M3 Dakar Yellow II
If you checked the voltage with the car running it should read 14 v with the alternator working. If it sits for a while and you measure the voltage with the car off, under 12.2 volts can do weird things at start and throw multiple codes.
12-29-2022, 10:43 AM | #7 | |
Rep 372
I'm waiting for an appointment slot to bring mines in. |
12-29-2022, 10:51 AM | #8 |
Rep 372
Thanks for chiming in. My running voltage was 14V at the time.
