01-19-2023, 06:53 AM | #1 |
Rep 6
Differences in the LCI taillights with and without LED bar
Im confused about the LCI taillights on my 2013 E82... The swirly bar on the back does not light up on mine, the halogen bulbs behind it does but the bar that swooshes upwards does not. Does that mean that there are differences in rear lights like there are the halogen and xenon headlights?
Would i be able to install the blackline rear lights with the LED bars on my car? My car came standard with the halogen headlights and FMR3 footwell module (atleast it says so on the bimercode app). VT96128 last 7 of VIN |
01-19-2023, 08:07 AM | #2 |
Rep 333
Drives: F10 535i xDrive, F25 xDrive35i
From what I understand, non-xenon cars will not have that LED bar light up on the tail lights.
I believe you can install taillights with the LED bar to light up but you may need to code. I’m sure someone else can chime in to confirm or correct me. |
01-20-2023, 12:26 PM | #3 |
Rep 938
Drives: G12 750Li
Yes it is possible, there are a few threads on the matter.
I myself found out the hard way when trying to figure out why my (what I thought did) strips weren’t lighting up. Turns out, halogen equipped cars do not get the led strips in the LCI taillights. That being said, ecs sells a blackline lci taillight kit for just under 400 dollars with the light up strips. The difference is an extra terminal that wraps around the outermost brake light. I’m sure it’s possible to do this with your originals but that would require you take off the lenses and put the strips in yourself. I don’t believe they’re in there and just need an extra wire, it’s a whole different setup. But they are plug and play once you get them
-2017 G12 750Li "Giulia"
-2014 F32 428i Xdrive "Bella" -2013 E82 128i "Austin" -2000 E38 750iL "Stella" |
01-31-2023, 10:10 AM | #4 | |
Rep 301
Drives: 2010 128i ZSP 6MT
01-31-2023, 10:12 AM | #5 |
Rep 938
Drives: G12 750Li
I believe you’re right I don’t think any of that is in the halogen assembly. It’s too bad there aren’t too many lci xenon parts cars, though there are enough parts out there still
Donkeyshins384.00 |
01-31-2023, 07:25 PM | #6 | |
Rep 301
